Instead of auto attendant I get fax tone.
xeonetworks
Currently I have a UC540 setup with call blast to all users. A secretary picks up the phone and transfers the calls accordingly. All calls operate perfectly never going to a fax tone or anything like that.
I'd like to setup an autoattendant however whenever I do 1 out of 3 calls appears to go to what sounds like a fax tone. This only occurs when the auto attendant is enabled.
Can anyone think of any reason why this happens? There are 3 lines going to the FXO ports, meaning 1 is left open with nothing connected to it.
7 Replies 7
paolo bevilacqua
Are you the end users ? Or who does configrue it for you?
I'm the person configuring it.
Tony Cilli Jr
This sounds like if all of the FXO lines that you call into are busy, they're rolling over to the customers Fax line. I'd have them busy out all of their phones, try calling the main number and see if it rings to the fax. Or call the provider and see the configuration for their rollover group. Just sounds like a rollover problem to me.
HTH,
Tony
Please rate if you feel my post was useful!
Ya I was thinking the same thing but did two things.
1. Unplug the fax machine, still happens!
2. With call blast, utilizing all 3 lines, I made another call and noticed the line just rings endlessly. No modem tones at all.
Hence why I'm pointing the finger at Auto Attendant.
Any other ideas?
Can I get the results of 'show run'?
If you don't want to post them here, I can be reached at acilli@goutsi.com. I'll see if I can find anything in your config that may cause it.
Tony
Hi Tony,
Very sorry for the delay. The summer was busy and I didn't have a chance to get to my customers office to load the config with the auto attendant, then revert back until this Friday. Nevertheless here is the config with passwords, hosts, user accounts removed. I will email it to you also. I did test it again, once in a while when a call comes in it goes to a fax tone. And I did check with the telco to ensure they have the call forwards (roll overs) setup correctly.
sh run
Building configuration...
Current configuration : 49348 bytes
! Last configuration change at 18:31:07 EDT Thu Sep 27 2012 by
version 15.1
parser config cache interface
no service pad
service password-encryption
service internal
service compress-config
service sequence-numbers
hostname gw
boot-start-marker
boot-end-marker
enable secret 4 *************
aaa new-model
aaa authentication login default local
aaa authentication login Foxtrot_sdm_easyvpn_xauth_ml_1 local
aaa authorization network Foxtrot_sdm_easyvpn_group_ml_1 local
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
crypto pki trustpoint TP-self-signed-287066119
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-287066119
revocation-check none
rsakeypair TP-self-signed-287066119
crypto pki certificate chain TP-self-signed-287066119
certificate self-signed 01
        quit
dot11 syslog
dot11 ssid *************
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 *************
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp excluded-address 192.168.14.1 192.168.14.99
ip dhcp excluded-address 192.168.14.150 192.168.14.255
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip dhcp pool data
import all
network 192.168.14.0 255.255.255.0
default-router 192.168.14.1
ip domain name host.com
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
ip ddns update method sdm_ddns1
HTTP
  add http://*************:*************@members.dyndns.org/nic/update?system=dyndns&hostname=*************@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
  remove http://*************:*************@members.dyndns.org/nic/update?system=dyndns&hostname=*************@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=
interval maximum 2 0 0 0
interval minimum 1 0 0 0
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp supplementary-services
port 0/0/0
  fallback-dn 405
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  registrar server expires max 3600 min 3600
  localhost dns:host.com
  no update-callerid
  sip-profiles 1000
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class sip-profiles 1000
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 10.1.1.1 port 5060
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
voice hunt-group 1 parallel
list 205,208,203,206,202,201,207,207,207,207,207,207,209,204
timeout 30
pilot 501
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
access-list 2
translation-profile incoming SIP_Incoming
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
access-list 3
voice translation-rule 410
rule 1 /^9\(.*\)/ /\1/
rule 15 /^...$/ /5555555555/
voice translation-rule 411
rule 1 /^9\(.*\)/ /ABCD9\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 422
rule 1 /^ABCD91900......./ //
rule 2 /^ABCD91976......./ //
rule 15 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile SIP_Passthrough_CallBlocking
translate called 422
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
fax interface-type fax-mail
license udi pid UC540W-FXO-K9 sn FGL161020BM
archive
log config
  logging enable
  logging size 600
  hidekeys
username user privilege 15 secret 4 **********
ip tftp source-interface Loopback0
class-map match-all _class_Voice0
match ip dscp ef
class-map match-all _class_Voice1
match ip dscp cs3
class-map match-any media
match  dscp ef
class-map match-any signaling
match  dscp cs3
match  dscp af31
policy-map Voice
class _class_Voice0
  set cos 6
class _class_Voice1
  set cos 3
policy-map queue
class signaling
  bandwidth percent 5
class media
  priority percent 60
class class-default
  fair-queue
policy-map shape
class class-default
  shape average 670000
  service-policy queue
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group EZVPN_GROUP_1
key *************
dns 8.8.8.8 4.4.4.4
pool SDM_POOL_1
acl 105
save-password
max-users 5
crypto isakmp profile sdm-ike-profile-1
   match identity group EZVPN_GROUP_1
   client authentication list Foxtrot_sdm_easyvpn_xauth_ml_1
   isakmp authorization list Foxtrot_sdm_easyvpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile sdm-ike-profile-1
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly in
interface FastEthernet0/0
description $ETH-WAN$
no ip address
load-interval 30
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
no ip address
macro description cisco-phone | cisco-phone | cisco-phone | cisco-phone | cisco-phone | cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
no ip address
interface FastEthernet0/1/8
switchport mode trunk
no ip address
macro description cisco-switch | cisco-switch | cisco-switch | cisco-switch | cisco-switch | cisco-switch
interface Dot11Radio0/5/0
no ip address
encryption vlan 1 mode ciphers aes-ccm
ssid wifi
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
antenna receive right
antenna transmit right
service-policy output Voice
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
interface Virtual-Template1 type tunnel
ip unnumbered BVI1
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
bridge-group 100 spanning-disabled
interface Dialer0
description $FW_OUTSIDE$
bandwidth 670
ip ddns update hostname *************
ip ddns update sdm_ddns1
ip address negotiated
ip access-group 104 in
ip mtu 1452
ip nat outside
ip inspect SDM_LOW out
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname ***********
ppp chap password 7 ************
ppp pap sent-username **************** password 7 ***********
ppp ipcp dns request
service-policy output shape
interface BVI1
ip address 192.168.14.1 255.255.255.0
ip access-group 102 in
ip nat inside
ip tcp adjust-mss 1412
interface BVI100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip local pool SDM_POOL_1 192.168.200.10 192.168.200.15
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.14.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 192.168.14.1
access-list 2 permit 10.1.10.0 0.0.0.3
access-list 2 permit 192.168.14.0 0.0.0.255
access-list 2 permit 10.1.1.0 0.0.0.255
access-list 2 permit 192.168.200.0 0.0.0.255
access-list 3 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 3 remark SDM_ACL Category=1
access-list 3 permit 174.137.63.206
access-list 3 deny   any
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp any host 10.1.10.2 eq non500-isakmp
access-list 101 permit udp any host 10.1.10.2 eq isakmp
access-list 101 permit esp any host 10.1.10.2
access-list 101 permit ahp any host 10.1.10.2
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip 192.168.14.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_5##
access-list 102 remark SDM_ACL Category=1
access-list 102 permit udp any host 192.168.14.1 eq non500-isakmp
access-list 102 permit udp any host 192.168.14.1 eq isakmp
access-list 102 permit esp any host 192.168.14.1
access-list 102 permit ahp any host 192.168.14.1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit udp any host 10.1.1.1 eq non500-isakmp
access-list 103 permit udp any host 10.1.1.1 eq isakmp
access-list 103 permit esp any host 10.1.1.1
access-list 103 permit ahp any host 10.1.1.1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny   ip 10.1.10.0 0.0.0.3 any
access-list 103 deny   ip 192.168.14.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_24##
access-list 104 remark SDM_ACL Category=1
access-list 104 permit udp host 174.137.63.206 eq 5060 any
access-list 104 permit udp host 174.137.63.206 any eq 5060
access-list 104 permit udp host 192.168.14.1 eq 5060 any
access-list 104 permit udp host 192.168.14.1 any eq 5060
access-list 104 permit udp any any range 16384 32767
access-list 104 permit udp any any eq non500-isakmp
access-list 104 permit udp any any eq isakmp
access-list 104 permit esp any any
access-list 104 permit ahp any any
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 deny   ip 192.168.14.0 0.0.0.255 any
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip host 0.0.0.0 any
access-list 104 deny   ip any any log
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_22##
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_13##
access-list 105 remark SDM_ACL Category=4
access-list 105 permit ip 192.168.14.0 0.0.0.255 any
access-list 105 permit ip 10.1.1.0 0.0.0.255 any
access-list 105 permit ip 10.1.0.0 0.0.255.255 any
dialer-list 1 protocol ip permit
snmp-server community public RO
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/50x-30x/spa50x-30x-7-4-9c.bin alias spa50x-30x-7-4-9c.bin
tftp-server flash:/phones/7940_7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:/phones/7940_7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:/phones/7940_7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/phones/7940_7960/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:/phones/7941_7961/apps41.9-1-1TH1-16.sbn alias apps41.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/cnu41.9-1-1TH1-16.sbn alias cnu41.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.9-1-1TH1-16.sbn alias cvm41sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/dsp41.9-1-1TH1-16.sbn alias dsp41.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.9-1-1TH1-16.sbn alias jar41sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/SCCP41.9-1-1SR1S.loads alias SCCP41.9-1-1SR1S.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
radius-server attribute 31 send nas-port-detail
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
signal groundStart
timeouts ringing infinity
station-id name temp
station-id number 401
caller-id enable
voice-port 0/0/1
shutdown
caller-id enable
voice-port 0/0/2
shutdown
caller-id enable
voice-port 0/0/3
shutdown
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 301
description Configured by CCA 4 FXO-0/1/0-Custom-AA
caller-id enable
voice-port 0/1/1
description Configured by CCA 4 FXO-0/1/1-Custom-AA
caller-id enable
voice-port 0/1/2
description Configured by CCA 4 FXO-0/1/2-Custom-AA
caller-id enable
voice-port 0/1/3
shutdown
description Configured by CCA 4 FXO-0/1/3-Custom-AA
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
corlist incoming user-internal
destination-pattern 401
port 0/0/0
no sip-register
dial-peer voice 2 pots
port 0/0/1
no sip-register
dial-peer voice 3 pots
port 0/0/2
no sip-register
dial-peer voice 4 pots
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description tcatch all dial peer for BRI/PRIv
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (host.com) **
session target sip-server
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1001 voip
corlist outgoing call-local
description ** star code to SIP trunk (host.com) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls for PSTN from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound Calls for MWI from CUE **
b2bua
incoming called-number A80T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1009 voip
description ** Passthrough Inbound Calls for Internal Extensions from CUE **
b2bua
incoming called-number ^...$
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1002 voip
preference 1
session target dns:host.com
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 80 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American-10-Digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 81 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 82 pots
trunkgroup ALL_FXO
description **CCA*North American-10-Digit*10-Digit Local**
preference 5
destination-pattern 9[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 83 pots
trunkgroup ALL_FXO
description **CCA*North American-10-Digit*Service Numbers**
preference 5
destination-pattern 9[2-9]11
forward-digits all
no sip-register
dial-peer voice 84 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*North American-10-Digit*Long Distance**
preference 5
destination-pattern 91[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 85 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American-10-Digit*International**
preference 5
destination-pattern 9011T
forward-digits all
no sip-register
dial-peer voice 86 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American-10-Digit*Toll-Free**
preference 5
destination-pattern 91800.......
forward-digits all
no sip-register
dial-peer voice 87 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91888.......
forward-digits all
no sip-register
dial-peer voice 88 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91877.......
forward-digits all
no sip-register
dial-peer voice 89 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91866.......
forward-digits all
no sip-register
dial-peer voice 90 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91855.......
forward-digits all
no sip-register
dial-peer voice 1042 voip
translation-profile outgoing PSTN_Outgoing
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1043 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1044 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1045 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1046 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1047 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1048 voip
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1049 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1050 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1051 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1052 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1053 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1054 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1055 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1056 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1057 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1058 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1059 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1060 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1061 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1062 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1063 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
no dial-peer outbound status-check pots
sip-ua
credentials username ************* password 7 ************ realm host.com
keepalive target dns:host.com
authentication username ************* password 7 *************
no remote-party-id
retry invite 2
retry register 10
timers connect 100
timers keepalive active 100
registrar dns:host.com expires 3600
sip-server dns:host.com
host-registrar
telephony-service
video
fxo hook-flash
max-ephones 40
max-dn 300
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message none
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
cnf-file perphone
load 7960-7940 P00308010200
load 7941 SCCP41.9-1-1SR1S
load 7941GE SCCP41.9-1-1SR1S
load 7961 SCCP41.9-1-1SR1S
load 7961GE SCCP41.9-1-1SR1S
load 521G-524G cp524g-8-1-17
load 501G spa50x-30x-7-4-9c
load 502G spa50x-30x-7-4-9c
load 504G spa50x-30x-7-4-9c
load 508G spa50x-30x-7-4-9c
load 509G spa50x-30x-7-4-9c
load 301 spa50x-30x-7-4-9c
load 303 spa50x-30x-7-4-9c
time-zone 12
keepalive 30 auxiliary 4
voicemail 399
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group logout HLog
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$pUkS$1cMGbw9TQXLKA2.YX6H5K.
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  1
number 101 no-reg primary
description IP-Paging1
name All Page
paging ip 239.1.1.1 port 2000
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  284  dual-line
number 222 no-reg both
label 222
description TEMPPHONE
name TEMPPHONE TEMPPHONE
ephone-dn  285  dual-line
number 221 no-reg both
label 221
description temp1
name TEMP TEMP
ephone-dn  286
number 5555555555
description SIP Main Number registration
preference 10
ephone-dn  287  dual-line
number 220 no-reg primary
label 220
description user
name user
translation-profile incoming CallBlocking
ephone-dn  288
number 300 no-reg primary
park-slot timeout 120 limit 2 recall retry 120 limit 2
label Call Park
ephone-dn  289  dual-line
number 205 no-reg primary
label 205
description user1
name user2
call-forward busy 399
call-forward noan 399 timeout 20
ephone-dn  290  dual-line
number 208 no-reg primary
label 208
description user2
name Warehouse user2
call-forward all 5555555555
ephone-dn  291  dual-line
number 209 no-reg primary
label 209
description user3
name Order user3
ephone-dn  292  dual-line
number 204 no-reg primary
label 204
description user4
name user4
ephone-dn  293  dual-line
number 207 no-reg primary
label 207
description user5
name user5
ephone-dn  294  dual-line
number 206 no-reg primary
label 206
description user6
name user6
ephone-dn  295  dual-line
number 203 no-reg primary
label 203
description user7
name user7
ephone-dn  296  dual-line
number 202 no-reg primary
label 202
description user8
name user8
ephone-dn  297  dual-line
number 201 no-reg primary
label 201
description user9
name user9
ephone-dn  298
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 399
ephone-dn  299
number A801... no-reg primary
mwi off
ephone-dn  300
number A800... no-reg primary
mwi on
ephone  1
device-security-mode none
mac-address 0019.564B.3E00
ephone-template 16
username "temp2" password *************
type 7941
button  1:284
ephone  2
mac-address 001C.BF14.D8BE
ephone-template 16
username ************* password *************
type CIPC
button  1:287
alias exec cca_voice_mode PBX
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.2 (1). Fri Jun 08 20:12:41 EDT 2012^^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
end
sh run
! Last configuration change at 18:31:07 EDT Thu Sep 27 2012 by nlnadmin
version 15.1
no service pad
service internal
hostname gw
boot-start-marker
boot-end-marker
aaa new-model
        quit
dot11 syslog
vlan 1
authentication open
guest-mode
ip source-route
ip cef
ip dhcp pool phone
ip dhcp pool data
import all
HTTP
no ipv6 cef
stcapp ccm-group 1
stcapp
port 0/0/0
  fallback-dn 405
trunk group ALL_FXO
max-retry 5
voice rtp send-recv
voice service voip
sip
  no update-callerid
  sip-profiles 1000
voice class codec 1
no-circuit
mode cme
timeout 30
pilot 501
access-list 2
access-list 3
rule 1 /.*/ //
rule 1 /^9/ //
rule 1 /^6/ //
voice-card 0
archive
log config
  logging enable
  logging size 600
  hidekeys
match ip dscp ef
match ip dscp cs3
match  dscp ef
match  dscp cs3
match  dscp af31
policy-map Voice
class _class_Voice0
  set cos 6
class _class_Voice1
  set cos 3
policy-map queue
class signaling
  bandwidth percent 5
class media
  priority percent 60
class class-default
  fair-queue
policy-map shape
class class-default
encr 3des
group 2
key *************
dns 8.8.8.8 4.4.4.4
pool SDM_POOL_1
acl 105
save-password
max-users 5
   virtual-template 1
bridge irb
interface Loopback0
ip nat inside
no ip address
load-interval 30
duplex auto
speed auto
ip nat inside
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ssid wifi
station-role root
bridge-group 1
ip unnumbered BVI1
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface Dialer0
bandwidth 670
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
interface BVI1
ip nat inside
interface BVI100
ip nat inside
ip http server
ip dns server
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
signal groundStart
caller-id enable
voice-port 0/0/1
shutdown
caller-id enable
voice-port 0/0/2
shutdown
caller-id enable
voice-port 0/0/3
shutdown
caller-id enable
voice-port 0/1/0
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
caller-id enable
voice-port 0/1/3
shutdown
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
sccp
sccp ccm group 1
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member emergency
member internal
member local
member emergency
member toll-free
member internal
member local
member local-plus
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
port 0/0/0
no sip-register
port 0/0/1
no sip-register
port 0/0/2
no sip-register
port 0/0/3
no sip-register
port 0/4/0
no sip-register
direct-inward-dial
port 0/1/0
port 0/1/1
port 0/1/2
port 0/1/3
port 0/1/0
no sip-register
port 0/1/1
no sip-register
port 0/1/2
no sip-register
port 0/1/3
no sip-register
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
permission term
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
no remote-party-id
retry invite 2
retry register 10
timers connect 100
host-registrar
telephony-service
video
fxo hook-flash
max-ephones 40
max-dn 300
max-redirect 20
service dss
system message none
cnf-file perphone
time-zone 12
voicemail 399
dn-webedit
time-webedit
transfer-pattern .T
fac standard
ephone-template  15
ephone-template  16
ephone-template  17
ephone-template  18
ephone-dn  1
name All Page
ephone-dn  9
description MoH
moh out-call ABC
label 222
label 221
description temp1
name TEMP TEMP
ephone-dn  286
number 5555555555
preference 10
label 220
description user
name user
ephone-dn  288
label Call Park
label 205
description user1
name user2
label 208
description user2
label 209
description user3
name Order user3
label 204
description user4
name user4
label 207
description user5
name user5
label 206
description user6
name user6
label 203
description user7
name user7
label 202
description user8
name user8
label 201
description user9
name user9
ephone-dn  298
ephone-dn  299
mwi off
ephone-dn  300
mwi on
ephone  1
ephone-template 16
type 7941
button  1:284
ephone  2
ephone-template 16
type CIPC
button  1:287
line con 0
line aux 0
line 2
no exec
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
end
Message was edited by: Nik Lavorato
