02-19-2013 06:50 AM - edited 03-16-2019 03:48 PM
Can I deploy CUCM on a separate server and integrate it with the CCX which is come with the BE6000 ?
02-19-2013 10:16 AM
Yes, but then we won't consider that deployment a CUCMBE 6K
It'll be a regular CUCM / UCCX deployment.
BE6K means you'll install the apps in the same server using the 6K OVAs and integrate them, and if necessary, add another 6K server for redundancy.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
02-19-2013 10:50 AM
If I used the 6K OVAs and installed the CUCM and CCX and I use that CCX to integrate it with another CUCM ?
Can I integrate CCX 9.X with CUCM8.6 ?
02-19-2013 05:17 PM
Yes, you can integrate UCCX 9.X with CUCM 8.6. You can use this link as a reference:
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
