Integrate Unity Connections 2.x with CUCM 6
fieryhail
Hello Everyone,
I've moved from running CUCM 6.01 to an MCS platform, it is actually an IBM x346 which recognizes as an MCS 7845-I.  Apparently I can not install Unified Communications Manager Business Edition on this particular MCS model.  So now I am going to have to install CallManager on the MCS and install Unity Connections on a separate server.  My question is how?  I assume I install the CallManager first, but then what steps do I have to take to install Unity Connections on another server and then register it to the CallManager server and integrate them so I can use Unity Connections for voicemail?  Any help on this is greatly appreciated.  Thanks in advance!
Jaime Valencia
Refer to the appropriate guide:
Configuration Guides
http://www.cisco.com/en/US/products/ps6509/products_installation_and_configuration_guides_list.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
