Integrating Unity Express with CUCM solution
ogor
Is it possible to integrate a Cisco Unity Express (NM-CUE module inside a CME) with a CUCM ?
if yes, how do I have to configure my router :
- in CME mode ?
- in SRST mode ?
- in CME in SRST mode ?
Thanks in advance
Olivier
joel
Yes, it is possible to integrate CUCM and CUE.
The CME router can be an SRST router as a backup for the CUCM.
Yes, you can also use CME in SRST mode which gives you more SRST functionality.
:JoeL
Thanks joel,
Do you have an url example about integrating a Unity Express with a CUCM ?
Olivier
I'm locating the URLs...I'll get them to you in a few...
