03-05-2013 10:26 AM - edited 03-16-2019 04:04 PM
I have a cisco cme router with fxo ports and an analog pabx system with diiferent extension numbers than IP telephony DN. Right now I have connected FXO ports with PABX through FXS ports on that side. Now I can dial PABX extensions from IP Phone but no calls can come from other side.
please help.
03-05-2013 11:10 AM
In the PBX you need to configure extensions for these FXO lines. after that you need to configure inbound dial-peer to match the inbound call from PBX, doing the proper voice translation and it should work.
I will assume that the PBX extension is 201, and CME extension is 301.
voice tranaslation-rule 1
rule 1 /201/ /301/
voice translation-profile in
translate called 1
dial-peer voice 1 pots
incoming called-number 2..
translation-profile incoming in
direct-inward-dial
port 0/0/0
Anas
please rate if it is helpful
03-05-2013 09:08 PM
Hi aabueideh,
Thnx for your reply. I want to explain a liitle bit about my scanario. Right now my analog PABX system extensions are only 3 digits long but my IP Phones DNs are 4 digits long. From PABX end I have 6 FXS lines connected to my Router FXO ports. I have configured a hunt group in analog PABX sytem to take these all 6 FXS lines when dial 77 but user hear a dial tone and after busy tone when try to reach my IP phones. In this scanario do I need to configure anything more or not?
Please help.
Arif
