12-17-2010 11:08 PM - edited 03-16-2019 02:30 AM
Dear All,
I have a Call Manager 8 installed in the HO. we have opened a new branch close to the HO. and the connection is wireless point to point connection.
the managment decide to implement uc540 in the new branch. I already installed and configured the UC540 in the new office.
Now my question is: I want the step be step how to integrate between the Call Manager in the HO and the UC540 in the new office.
Thanks a lot for support..
12-18-2010 09:45 AM
You will need to configure either an H323 gateway or a SIP trunk in CUCM for the UC540, and use SIP/H323 dial peers on the UC to direct calls to and from the central office. Treat this just like you would treat any other H323/SIP integration with a remote gateway.
Keep in mind, if you are using Unity Express for voicemail, you will need to configure CUBE statements under voice service voip:
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
12-19-2010 12:00 AM
I forget to mention that I have configured the Cisco 2811 as a MGCP Gateway with the call manager.
so the SIP/H323 dial peers will be configured on the Router or on the UC Manager, and How?
Thanks a lot for your help and support..
