Integration between CUBE and 3CX Phone System
scottyb01
Has anyone had any success setting up a SIP trunk between a CUBE and 3CX phone system. The SIP trunk is not registering, but when I make calls to extensions on the 3CX I can see it Invite, Try, Authenticate, Acknowledged, and then I get a 404 User unknown (from the 3CX), and then a 404 Not Found. Below are my configs and I've attached the debugs from the call. Any help would be greatly appreciated.
voice service voip
ip address trusted list
ipv4 10.130.5.9 255.255.255.255
sip-ua
credentials username 10001 password 7 154F23060A280A17256A122F realm 3CXPhoneSystem
authentication username 10001 password 7 03597301080D007F43503E08 realm 3CXPhoneSystem
retry invite 3
retry response 3
retry bye 3
retry cancel 3
retry register 10
timers trying 150
timers expires 300000
no timers hold
timers register 1000
registrar ipv4:10.130.5.9 expires 3600
sip-server ipv4:10.130.5.9
dial-peer voice 2000 voip
description SIP Trunk to 3CX
destination-pattern 13..
session protocol sipv2
session target ipv4:10.130.5.9
session transport udp
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/0
voice-class sip bind media source-interface GigabitEthernet0/0
dtmf-relay rtp-nte
no vad
sh sip-ua register status shows the following
Line peer expires(sec) reg survival P-Associ-URI
10001 -1 43 no normal
shaijal.allipra
Are you able integrate successfully with 3CX?
Instead of CUBE I tried with CUCM 'SIP Realm' however calls still failing with '407 Proxy Authentication Require' I followed below doc.
https://community.cisco.com/t5/ip-telephony-and-phones/cucm-11-5-sip-trunk-to-3cx/td-p/3043547?dtid=osscdc000283
CUCM Ver 11.5
The above config actually ended up working, but changes had to be made on the 3CX side. I'm not sure what they changed, but it came up with no problems
Thanks for your reponse.
On 3CX  SIP trunk General Tab 'Type of Authentication' ? what did you selected
3 Way Authentication - Is this nee to enable
