Integration CUE and CUCM
Bruno Rangel
Hi All
I´m using the CUE 8.6.1, i need to integrate with CUCM 8, I´ve created the CTI Route Point and CTI port associated to JTAPI user as well.But I cannot register the CTI with CUE, when I try add the CTI port got the error "CTI Port maximum limit exceeded".
See the Screen for my license status on the CUE
Could you please help how configure my AA, if there are any way to do that
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
2 Accepted Solutions
Chris Deren
Bruno,
This is licensing issue, notice you only have 2 permanent IVR ports, but there are no voicemail port permanent licenses, did you buy any ports and if so you need to register the PAKs and upload and activate on CUE.
This type of question/issue is frequenty asked here, so searching this forum should reveal many good similar threads.
HTH,
Chris
Bruno,
You are most correct, CUE ports are licensed and each port corresponds to concurrent call.
HTH,
Chris
Chris Deren
Bruno,
HTH,
Chris
Hey Chris thanks for your help! (+5)
Now I have a doubt 2 Ports for AA means just 2 simultaneous calls?
Cheers
Bruno Rangel
Cheers
Bruno Rangel
Bruno,
HTH,
Chris
Hey Chris thanks once again....
Cheers
Bruno Rangel
"Se você quiser alguém em quem confiar, confie em si mesmo. Quem acredita sempre alcança"
Renato Russo
Cheers
Bruno Rangel
