Inter-Cluster
phartl
Hello Community,
Is it possible to route calls between locations via WAN with the help of dial-peers instead of Inter-Cluster Trunks ? (For example - I have no possibility to user ICT). Are there any restrictions or problem ?
thx
Patze
Jaime Valencia
Assuming you have a GW configured at each cluster and that they are correctly configured that should work.
You might be able to do this with just 1 GW in the middle.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Ming Yuan Chiu
Level 4
Level 4
Yes, you can trunk via SIP.  This should allow for multi-vendor integration via dial-peers to Astrix, Avaya etc.
