Intercluster dial peer
amarjit4321
Dear All,
I have a scenario in Lab where I have configured two clusters. Please see the below scenario.
All the phones in 1XX are registered to CUCM and 2XXX are registered to CME and can call to each other in the same cluster.
Now I want to make calls from 1XXX to 2XXX, so what will be dial peer I need to configure in the routers.
Amarjit Das
20 Replies 20
No, I have not configured any partitions.
Amarjit Das
Please find the latest debug details below --
Voice Gateway --
*Mar  1 02:40:45.371: //-1/2B88C4988041/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2001, Called Number=1001, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  1 02:40:45.379: //-1/2B88C4988041/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=12
*Mar  1 02:40:45.395: //-1/2B88C4988041/DPM/dpAssociateIncomingPeerCore:
*Mar  1 02:40:45.399: //-1/2B88C4988041/DPM/dpAssociateIncomingPeerCore:
*Mar  1 02:40:45.459: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=1001, Called Number=1001, Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  1 02:40:45.463: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=1001
*Mar  1 02:40:45.467: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
*Mar  1 02:40:45.471: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=11
*Mar  1 02:40:45.475: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1001, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=11
*Mar  1 02:40:45.483: //-1/2B88C4988041/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1001, Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  1 02:40:45.483: //-1/2B88C4988041/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=11
VOICE-GW#
VOICE-GW#
VOICE-GW#
VOICE-GW#
*Mar  1 02:40:53.087: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/1 (not full duplex), with CME.lab.local FastEthernet0/0 (full duplex).
VOICE-GW#u all
All possible debugging has been turned off
VOICE-GW#=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.02.19 18:45:08 =~=~=~=~=~=~=~=~=~=~=~=
*Mar  1 03:40:43.635: //-1/8C4612CA8069/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:40:43.639: //-1/8C4612CA8069/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:40:43.655: //-1/8C4612CA8069/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:40:43.663: //-1/8C4612CA8069/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:40:43.699: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 03:40:43.703: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 03:40:43.707: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 03:40:43.707: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=11
*Mar  1 03:40:43.711: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:40:43.727: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 03:40:43.731: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 03:40:43.735: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 03:40:43.735: //-1/8C4612CA8069/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=11
CME Router --
*Mar  1 01:47:49.155: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2001, Called Number=, Voice-Interface=0x65ECD080,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
*Mar  1 01:47:49.159: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20001
*Mar  1 01:47:49.675: //-1/2B88C4988041/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1, Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  1 01:47:49.679: //-1/2B88C4988041/DPM/dpMatchPeersCore:
CME#
   Result=Partial Matches(1) after DP_MATCH_DEST
*Mar  1 01:47:49.683: //-1/2B88C4988041/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
*Mar  1 01:47:49.867: //-1/2B88C4988041/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=10, Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  1 01:47:49.871: //-1/2B88C4988041/DPM/dpMatchPeersCore:
*Mar  1 01:47:49.871: //-1/2B88C4988041/DPM/dpMatchPeersMoreArg:
*Mar  1 01:47:50.067: //-1/2B88C4988041/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=100, Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  1 01:47:50.071: //-1/2B88C4988041/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.071: //-1/2B88C4988041/DPM/dpMatchPeersMoreArg:
*Mar  1 01:47:50.267: //-1/2B88C4988041/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.271: //-1/2B88C4988041/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.271: //-1/2B88C4988041/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 01:47:50.283: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.287: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.287: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 01:47:50.299: //-1/2B88C4988041/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.303: //-1/2B88C4988041/DPM/dpMatchPeersCore:
*Mar  1 01:47:50.303: //-1/2B88C4988041/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 01:47:50.487: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/0 (not half duplex), with VOICE-GW FastEthernet0/1 (half duplex).
CME#
CME#u all
CME#
CME#=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.02.19 18:44:56 =~=~=~=~=~=~=~=~=~=~=~=
*Mar  1 02:47:47.431: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Mar  1 02:47:47.435: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Mar  1 02:47:47.951: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
CME#
*Mar  1 02:47:47.955: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:47.955: //-1/8C4612CA8069/DPM/dpMatchPeersMoreArg:
*Mar  1 02:47:48.143: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.147: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.147: //-1/8C4612CA8069/DPM/dpMatchPeersMoreArg:
*Mar  1 02:47:48.343: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.347: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.347: //-1/8C4612CA8069/DPM/dpMatchPeersMoreArg:
*Mar  1 02:47:48.543: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.547: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.551: //-1/8C4612CA8069/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 02:47:48.563: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.567: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 02:47:48.575: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.579: //-1/8C4612CA8069/DPM/dpMatchPeersCore:
*Mar  1 02:47:48.583: //-1/8C4612CA8069/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Calling number -- 2001
Called Number -- 1001
Amarjit Das
you have posted the output of 'debug voip dialpeer' not 'debug voip ccapi inout'. Could you please capture 'debug voip ccapi inout'?
//Suresh
Please rate all the useful posts.
//Suresh Please rate all the useful posts.
Hi Suresh,
Please find the debug details below --
Voice Gateway --
*Mar  1 04:11:53.186: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/1 (not full duplex), with CME.lab.local FastEthernet0/0 (full duplex).
VOICE-GW#
VOICE-GW#
*Mar  1 04:12:05.346: //-1/EC2BC7B38080/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=172.16.0.2
   ----- ccCallInfo IE subfields -----
   cisco-ani=2001
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=1001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Mar  1 04:12:05.362: //-1/EC2BC7B38080/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x671BACAC, Call Info(
   Calling Number=2001,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1001(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=37
*Mar  1 04:12:05.362: //-1/EC2BC7B38080/CCAPI/ccCheckClipClir:
   In: Calling Number=2001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=2001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Mar  1 04:12:05.366: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar  1 04:12:05.366: :cc_get_feature_vsa malloc success
*Mar  1 04:12:05.366:  cc_get_feature_vsa count is 1
*Mar  1 04:12:05.370: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar  1 04:12:05.370: :FEATURE_VSA attributes are: feature_name:0,feature_time:1712564096,feature_id:37
*Mar  1 04:12:05.370: //37/EC2BC7B38080/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=2001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1001(TON=Unknown, NPI=Unknown))
*Mar  1 04:12:05.382: //37/EC2BC7B38080/CCAPI/cc_process_call_setup_ind:
   Event=0x66149678
*Mar  1 04:12:05.402: //37/EC2BC7B38080/CCAPI/ccCallSetContext:
   Context=0x676E6268
*Mar  1 04:12:05.402: //37/EC2BC7B38080/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 37 with tag 10 to app "_ManagedAppProcess_Default"
*Mar  1 04:12:05.414: //37/EC2BC7B38080/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
*Mar  1 04:12:05.434: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Mar  1 04:12:05.438: : updating existing feature vsa
*Mar  1 04:12:05.438: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Mar  1 04:12:05.442:  feature call basic
*Mar  1 04:12:05.446: //37/EC2BC7B38080/CCAPI/ccCallDisconnect:
   Cause Value=3, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=3, Call Entry(Responsed=TRUE, Cause Value=3)
*Mar  1 04:12:05.450: //37/EC2BC7B38080/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Mar  1 04:12:05.462: //37/EC2BC7B38080/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x671BACAC, Tag=0x0, Call Id=37,
   Call Entry(Disconnect Cause=3, Voice Class Cause Code=0, Retry Count=0)
*Mar  1 04:12:05.470: //37/EC2BC7B38080/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
*Mar  1 04:12:05.474: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar  1 04:12:05.474: :cc_free_feature_vsa freeing 6613A778
*Mar  1 04:12:05.478: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar  1 04:12:05.478:  vsacount in free is 0
CME Router  --
*Mar  1 03:18:50.479: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/0 (not half duplex), with VOICE-GW FastEthernet0/1 (half duplex).
CME#
*Mar  1 03:19:06.307: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:19:06.311: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Mar  1 03:19:06.323: //-1/EC2BC7B38080/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=2001
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
*Mar  1 03:19:06.339: //-1/EC2BC7B38080/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x65ECD080, Call Info(
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20001, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Mar  1 03:19:06.343: //-1/EC2BC7B38080/CCAPI/ccCheckClipClir:
*Mar  1 03:19:06.347: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar  1 03:19:06.347: :cc_get_feature_vsa malloc success
*Mar  1 03:19:06.347:  cc_get_feature_vsa count is 1
*Mar  1 03:19:06.351: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar  1 03:19:06.351: :FEATURE_VSA attributes are: feature_name:0,feature_time:1719764832,feature_id:53
*Mar  1 03:19:06.351: //53/EC2BC7B38080/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=(TON=Unknown, NPI=Unknown))
*Mar  1 03:19:06.363: //53/EC2BC7B38080/CCAPI/cc_process_call_setup_ind:
   Event=0x66826990
*Mar  1 03:19:06.375: //53/EC2BC7B38080/CCAPI/ccCallSetContext:
   Context=0x66C81A50
*Mar  1 03:19:06.379: //53/EC2BC7B38080/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 53 with tag 20001 to app "_ManagedAppProcess_Default"
*Mar  1 03:19:06.403: //53/EC2BC7B38080/CCAPI/ccCallSetupAck:
   Call Id=53
*Mar  1 03:19:06.403: //53/EC2BC7B38080/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
*Mar  1 03:19:06.407: //53/EC2BC7B38080/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=53
*Mar  1 03:19:06.411: //53/EC2BC7B38080/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
*Mar  1 03:19:06.415: //53/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x35, digit_event=0x1, enable=TRUE, consume=FALSE)
*Mar  1 03:19:06.415: //53/EC2BC7B38080/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=53
*Mar  1 03:19:06.419: //53/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x65ECD080, callID=0x35, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*Mar  1 03:19:06.419: //53/EC2BC7B38080/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x65ECD080, Call Id=53
*Mar  1 03:19:06.423: //53/EC2BC7B38080/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
*Mar  1 03:19:07.415: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=53, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x202A60, Rtp Expiration=0x0
*Mar  1 03:19:07.419: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_end:
   Source Call Id=53, Digit=1, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
*Mar  1 03:19:07.423: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_end:
   Call Entry(Handoff Depth=0)
*Mar  1 03:19:07.435: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:07.439: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:07.439: //-1/EC2BC7B38080/DPM/dpMatchPeersMoreArg:
*Mar  1 03:19:08.763: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_begin:
   Source Call Id=53, Digit=0, DigitBeginFlags=0x0,
   Rtp Timestamp=0x20A760, Rtp Expiration=0x0
*Mar  1 03:19:08.767: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_end:
   Source Call Id=53, Digit=0, Duration=100,
*Mar  1 03:19:08.775: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:08.779: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:08.779: //-1/EC2BC7B38080/DPM/dpMatchPeersMoreArg:
*Mar  1 03:19:08.919: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x212460, Rtp Expiration=0x0
*Mar  1 03:19:08.923: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_end:
*Mar  1 03:19:08.931: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:08.935: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:08.935: //-1/EC2BC7B38080/DPM/dpMatchPeersMoreArg:
*Mar  1 03:19:10.211: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x21A160, Rtp Expiration=0x0
*Mar  1 03:19:10.215: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_end:
*Mar  1 03:19:10.219: //53/EC2BC7B38080/CCAPI/cc_api_call_digit_end:
*Mar  1 03:19:10.223: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:10.227: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:10.227: //-1/EC2BC7B38080/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 03:19:10.231: //53/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x35, digit_event=0x0, enable=FALSE, consume=FALSE)
*Mar  1 03:19:10.231: //53/EC2BC7B38080/CCAPI/ccCallReportDigits:
*Mar  1 03:19:10.235: //53/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x65ECD080, callID=0x35, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
*Mar  1 03:19:10.239: //53/EC2BC7B38080/CCAPI/cc_api_call_report_digits_done:
*Mar  1 03:19:10.251: //53/EC2BC7B38080/CCAPI/ccCallProceeding:
*Mar  1 03:19:10.251: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 03:19:10.255: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Mar  1 03:19:10.259: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 03:19:10.267: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:10.271: //-1/EC2BC7B38080/DPM/dpMatchPeersCore:
*Mar  1 03:19:10.271: //-1/EC2BC7B38080/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
*Mar  1 03:19:10.279: //53/EC2BC7B38080/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=10, Params=0x66C82918, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Mar  1 03:19:10.279: //53/EC2BC7B38080/CCAPI/ccCheckClipClir:
*Mar  1 03:19:10.283: //53/EC2BC7B38080/CCAPI/ccCheckClipClir:
*Mar  1 03:19:10.283: //53/EC2BC7B38080/CCAPI/ccCallSetupRequest:
   Destination Pattern=1..., Called Number=1001, Digit Strip=FALSE
*Mar  1 03:19:10.287: //53/EC2BC7B38080/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=FALSE,
   Guid=EC2BC7B3-2BF9-11D6-8080-9E453EAF7E4F, Outgoing Dial-peer=10
*Mar  1 03:19:10.287: //53/EC2BC7B38080/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=2001
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=1001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Mar  1 03:19:10.295: //53/EC2BC7B38080/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x66043D40, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=2001,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1001(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=10, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Mar  1 03:19:10.299: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar  1 03:19:10.299: :cc_get_feature_vsa malloc success
*Mar  1 03:19:10.299:  cc_get_feature_vsa count is 2
*Mar  1 03:19:10.299: :FEATURE_VSA attributes are: feature_name:0,feature_time:1719765048,feature_id:54
*Mar  1 03:19:10.303: //54/EC2BC7B38080/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
*Mar  1 03:19:10.303: //54/EC2BC7B38080/CCAPI/ccCallSetContext:
   Context=0x66C828C8
*Mar  1 03:19:10.307: //53/EC2BC7B38080/CCAPI/ccSaveDialpeerTag:
*Mar  1 03:19:10.643: //54/EC2BC7B38080/CCAPI/cc_api_call_disconnected:
   Cause Value=3, Interface=0x66043D40, Call Id=54
   Call Entry(Responsed=TRUE, Cause Value=3, Retry Count=0)
*Mar  1 03:19:10.647: //53/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
*Mar  1 03:19:10.651: //54/EC2BC7B38080/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=54
*Mar  1 03:19:10.651: //54/EC2BC7B38080/CCAPI/ccCallDisconnect:
   Cause Value=3, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=3)
*Mar  1 03:19:10.655: //54/EC2BC7B38080/CCAPI/ccCallDisconnect:
*Mar  1 03:19:10.655: //54/EC2BC7B38080/CCAPI/cc_api_get_transfer_info:
*Mar  1 03:19:10.675: //54/EC2BC7B38080/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x66043D40, Tag=0x0, Call Id=54,
*Mar  1 03:19:10.679: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar  1 03:19:10.679: :cc_free_feature_vsa freeing 66818830
*Mar  1 03:19:10.679:  vsacount in free is 1
*Mar  1 03:19:10.695: //53/EC2BC7B38080/CCAPI/ccCallDisconnect:
*Mar  1 03:19:10.699: //53/EC2BC7B38080/CCAPI/cc_api_get_transfer_info:
*Mar  1 03:19:17.307: //53/EC2BC7B38080/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x65ECD080, Tag=0x0, Call Id=53,
*Mar  1 03:19:17.311: //53/EC2BC7B38080/CCAPI/cc_api_call_disconnect_done:
*Mar  1 03:19:17.315: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar  1 03:19:17.315: :cc_free_feature_vsa freeing 66818758
Amarjit Das
Hi Das,
can u try adding session protocol sipv2 in CME router under
dial-peer voice 10 voip
destination-pattern 1...
voice-class codec 1
session target ipv4:172.16.0.1
regds,
aman
Hi Mr.Aman,
Yes, after adding the said command it works fine.
Now I can call both way.
Thanks for your support.
Amarjit Das
