09-14-2018 10:42 PM - edited 03-17-2019 01:28 PM
On a site 4 intercoms are connected at different entry & exit points.These are registered with Call manager via SIP having individual extensions each(eg 1001-1004). The intercoms are then configured to relay inputs on a different extension(2011).
Whenever someone pushes the buttons on these intercoms, it places a call on extension 2011 resulting a ring for that 2011 number. This 2011 is being shared as additional DN's among 2 different staff who also
have their own separate extensions for non-intercom related calls.
It has been seen that some of the intercoms when pressed doesn't result in a ring on extension 2011.
The intercoms all appear registered correctly.
Can someone please help with suggestions on how to check whats happening with no ringing on the
extension when intercoms are pressed. Any inputs will be greatly appreciated, as this is having major problems at that office.
Thanks in advance.
Solved! Go to Solution.
09-15-2018 10:57 AM
09-15-2018 10:57 AM
09-16-2018 03:54 AM
