11-01-2016 08:06 PM - edited 03-17-2019 08:33 AM
Dear All :
thank you very much for this fantastic Support Community
i have the following case: two sites : headquarter with CCUM and branch site with voice gateway cisco router 3845 configured as SSRT mode as following :
- on call manager(10.50.3.11) the SRST congiguration is done to refer to the branch voice gateway
10.51.3.15 port:2000
- on the branch voice gateway(10.51.3.15), the configuration is :
dial-peer voice 10 voip
description ---- Accept & Send CCM2
destination-pattern 1.....
session target ipv4:10.50.3.12
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 11 voip
description ---- Accept & Send CCM1
preference 1
session target ipv4:10.50.3.11
voice-class codec 1
voice-class h323 1
no vad
application
global
service alternate default
call-manager-fallback
secondary-dialtone 9
max-conferences 4 gain -6
transfer-system full-consult
ip source-address 10.51.3.15 port 2000
max-ephones 80
max-dn 90
application sccp_application
system message primary System on Backup Mode
dialplan-pattern 1 1..... extension-length 5
transfer-pattern ......
keepalive 20
pickup 222
multicast moh 239.1.1.1 port 16384 route 10.51.3.15
time-format 24
date-format dd-mm-yy
i am using the dial plan 1..... and when the two WAN links are down between the two sites the network configuration on each cisco ip phone in the branch shows SRST as third call manager but the ip phones inside that branch can't call each other ?did i miss any step ,
i think my dial peer(10,11) is not working on the SRST mode since they are still referring to the call manager
please help
11-02-2016 05:44 AM
You only have dial peers to CUCM, and I don't see any PSTN dial peers. Can you post the entire "show run" so we can determine which protocol you use MGCP vs SIP vs H323 and type of PSTN trunks you have?
11-02-2016 06:15 AM
11-02-2016 06:24 AM
Looks like you have many POTS dial peers pointing to PSTN. Replicate the issue and provide "debug voice ccapi inout" and "debug voice dialpeer"
11-02-2016 06:49 AM
Dear Chris:
when fallback ,i don't want anything to go over PSTN ,
i want just the internal ip phones in the branch to call each other in that branch ...
hope that understood
11-02-2016 06:53 AM
You could use after-hours block pattern feature with 24x7 option:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/command/reference/cme_cr/cme_a1ht.html#wp3719778986
