09-06-2011 02:11 PM - edited 03-16-2019 06:51 AM
Hi All,
Our external MOH works but internal fails. The wav file is being played from the GW. I am using 239.2.1.1 as the Base Multi-cast IP Address because one of our SUBs is sourcing the MOH. I am using the same address under Call-Manager-Fallback. Could you please let me know if I am missing anything in the config.
MK
Solved! Go to Solution.
09-13-2011 07:20 AM
Hey Bill,
A quick question for you. Under Call-Manager-Fallback, I am using the loopback0 IP address for the MOH. The ip pim sparse-mode command is configured under loopback0 interface. The show ip pim neighbor shows only the IP address of the loopback0 interface. I was wondering if that could be the issue for my internal MOH.
MK
09-13-2011 07:29 AM
No, I don't think so. I would think that you would be streaming MoH to internal hosts from your CUCM.
Bill
