Internationl Mobile calls failed on h323 gateway
alap84
when i am calling to internetnational mobile number it showing ringout than after little long time busy tone ... attaching following
debug isdn q921 is              ON.
Dec 30 09:45:01.144: ISDN Se0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=5 nr=1
14
Dec 30 09:45:01.160: ISDN Se0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=6
Dec 30 09:45:01.248: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=114 nr
=6
Dec 30 09:45:01.252: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=115
Dec 30 09:45:04.280: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=115 nr
=6
Dec 30 09:45:04.284: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=116
Dec 30 09:45:04.292: ISDN Se0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=6 nr=1
16
Dec 30 09:45:04.300: ISDN Se0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=7
Dec 30 09:45:04.400: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=116 nr
=7
Dec 30 09:45:04.404: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=117
Dec 30 09:45:06.672: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=117 nr
=7
Dec 30 09:45:06.676: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=118
Dec 30 09:45:16.676: ISDN Se0/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=118
Dec 30 09:45:16.676: ISDN Se0/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=7
Dec 30 09:45:16.680: ISDN Se0/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=118
Dec 30 09:45:16.684: ISDN Se0/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=7
Dec 30 09:45:26.684: ISDN Se0/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=7
Dec 30 09:45:26.688: ISDN Se0/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=118
Dec 30 09:45:28.452: ISDN Se0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=7 nr=1
18
Dec 30 09:45:28.460: ISDN Se0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=8
Dec 30 09:45:28.500: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=118 nr
=8
Dec 30 09:45:28.504: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=119
Dec 30 09:45:28.508: ISDN Se0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=8 nr=1
19
Dec 30 09:45:28.516: ISDN Se0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=9u all
Dec 30 09:45:30.052: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=119 nr
=9
Dec 30 09:45:30.052: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=120
Dec 30 09:45:30.060: ISDN Se0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=9 nr=1
20
Dec 30 09:45:30.076: ISDN Se0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=10
Dec 30 09:45:30.216: ISDN Se0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=120 nr
=10
Dec 30 09:45:30.220: ISDN Se0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=121
debug isdn q931 is              ON.
Dec 30 09:46:18.016: ISDN Se0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x18E4
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98392
                Exclusive, Channel 18
        Calling Party Number i = 0x0081, '919'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '00xxxxxxxxxxxx' (number omitted)
Dec 30 09:46:18.100: ISDN Se0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x98E
Dec 30 09:46:20.804: ISDN Se0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x98
D5
        Cause i = 0x8090 - Normal call clearing
Dec 30 09:46:20.816: ISDN Se0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x18D5
Dec 30 09:46:20.912: ISDN Se0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x
98D5
Dec 30 09:46:23.452: ISDN Se0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x98E4
        Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band inf
o
        Progress Ind i = 0x8288 - In-band info or appropriate now available u al
l
Dec 30 09:46:46.832: ISDN Se0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x98
E4
        Cause i = 0x839F - Normal, unspecified
Dec 30 09:46:46.840: ISDN Se0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x18E4
Dec 30 09:46:46.960: ISDN Se0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x
98E4
Dec 30 09:46:50.552: ISDN Se0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x1E
4D
        Cause i = 0x8290 - Normal call clearing
Dec 30 09:46:50.560: ISDN Se0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x9E4D
Dec 30 09:46:50.692: ISDN Se0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x
1E4D
interface Serial0/0:15
no ip address
no logging event link-status
isdn switch-type primary-net5
isdn incoming-voice voice
isdn T306 60000
isdn T310 50000
no cdp enable
Joseph Martini
Looks like the provider is disconnecting the call:
D5
Have you tried contacting them?
Chris Deren
Fix your caller ID as you are sending only 919, provider must not like it.
HTH,
Chris
