INVITE records with a CP-8841-3PCC
wolfzeh
Hello, so far I am an individual user experiencing to setup a CP-8841-3PCC on base of pure web client (no CUCM) to a router providing SIP fuctionality (here: Fritz!Box7490)
Actually, incoming calls can be received properly (which implies registration goes ok), however outgoing calls (networkwise processed as INVITE in SIP) are not  at all handled.
In order to sort this out, I am wondering, which settings  under Voice => Ext x may be relevant to formulate the "From" field different to
From: "Anonymous" <sip:anonymous@anonymous.invalid>.
In appreciation on each comment / tip
Wolfgang
Geovani
Hi there, difficult to know whats  happening without looking at the configuration and logs.
Are you using UDP or TCP for signaling?
