IOS DHCP lease time corresponds with phones unregistering
mmedwid
Level 3
Level 3
I have finally found a solid correlation to explain why some phone reboot at one of my sites.
If I find the time that a phone unregisterd from the UCM 7.1 server and then look at the
DHCP lease table - the lease expiry is inevitably five minutes before the unregistration.
I toss this out in case anyone else has seen this.  The fix should be to simply change
lease times to infinite.  The bad effect was that phones would drop calls in progress while
the DHCP lease would renew.  The lease timer was at default which is 1 day.  The phones
unregistering and losing calls did not occur with every phone and the symptom could
randomly affect any particular phone.
Should I report this as a bug?  If so - how?
Jonathan Schulenberg
Have you performed a packet capture or reviewed the DHCP server logs to understand why the server is not providing a renewal to the phone? The phone makes a renewal request when 50% of the lease time remains. It should never get to the expiry threshold - and then totally release the address - unless the DHCP server has been denying the renewal request.
I caught a little big of event debug as you can see below.  But my main priority is to get this fixed.  So as soon as I verified the correlation I changed the lease to infinite. The config is below too.
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.65.1 10.10.65.40
ip dhcp pool Phones
   network 10.10.65.0 255.255.255.0
   option 150 ip 10.10.10.72
   default-router 10.10.65.1
   dns-server 10.10.25.25 10.10.101.139
   domain-name xyz.com
010352: Mar  4 22:41:47.536: DHCPD: checking for expired leases.
010353: Mar  4 22:43:13.892: DHCPD: Sending notification of ASSIGNMENT:
010354: Mar  4 22:43:13.892:  DHCPD: address 10.10.65.52 mask 255.255.255.0
010355: Mar  4 22:43:13.896:   DHCPD: htype 1 chaddr 6c50.4d57.049f
010356: Mar  4 22:43:13.896:   DHCPD: lease time remaining (secs) = 86400
now it looks like..
012271: Mar  5 04:39:47.618: DHCPD: checking for expired leases.
012272: Mar  5 04:40:27.414: DHCPD: Sending notification of ASSIGNMENT:
012273: Mar  5 04:40:27.414:  DHCPD: address 10.10.65.77 mask 255.255.255.0
012274: Mar  5 04:40:27.414:   DHCPD: htype 1 chaddr e804.6212.75b7
012275: Mar  5 04:40:27.414:   DHCPD: lease time remaining (secs) = 4294967295
