IOS Multicast MOH using mgcp gateway
mreilly
I have multicast moh set up with callmanager 5.1 and a 2811 gateway. I must be doing something right when a call comes in from the pstn to an ip phone, the call is then placed on hold. I here silence which leads me to believe it is an IOS issue. Has anyone experienced this? If so any advice?
dgahm
Level 8
Level 8
If MGCP, do you have this command in the 2811?
ccm-manager music-on-hold
mreilly
Figured out my problem had multicast 239.1.1.3 on router and 239.1.1.1 in callmanager. All set
What command did you use to configure that on the router? "ip igmp join-group 239.1.1.1"?
