IOS - Multiple SIP-UA Support?
aronjsmith
I have an IOS voip router and an Asterisk PBX. Some FXS ports are registered as extensions on the PBX. I would like to also provide IP-IP gateway to a SIP provider on this router, but do not want the router to attempt to register the FXS ports with the provider for obvious reasons (and using different username/passwords). Can I accomplish this with a single router? Or do I need to have multiple routers for FXS and IP-IP gateway on each separately?
Any help appreciated. Thanks.
ajs
gogasca
Level 10
Level 10
Afaik Cisco IOS will not register to more than one SIP registrar simultaneously. The 'secondary' will only come into play if the first registrar goes down. There is no load-balancing.
