ā01-08-2012 06:32 PM - edited ā03-16-2019 08:52 AM
Hi!
I have a ISR G2 2911 box with a basic CUCME 9.0 config and a PC with IP Communicator 8.6 installed.
The IPC gets registered but fails to change its locale to Russian. Here is the relevant part of the config:
Cisco2911#sh run
telephony-service
max-ephones 10
max-dn 10
ip source-address 192.168.0.1 port 2000
auto assign 1 to 10
cnf-file location flash:
cnf-file perphone
user-locale RU load CME-locale-ru_RU-Russian-8.8.2.3.tar
network-locale RU
time-zone 34
time-format 24
max-conferences 8 gain -6
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 2
number 1112
name Test
ephone 2
mac-address 60EB.695E.B160
type CIPC
button 1:2
Then,
Cisco2911#sh telephony-service
CONFIG (Version=9.0)
Version 9.0
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
max-ephones 10
max-dn 10
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
cnf-file location: flash:
cnf-file option: PER-PHONE
network-locale[0] RU (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] RU (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 24
date-format mm-dd-yy
timezone 34 Caucasus Standard/Daylight Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
edit DN through Web: enabled.
edit TIME through web: enabled.
background save interval 10 minutes
Log (table parameters):
max-size: 150
retain-timer: 15
transfer-digit-collect new-call
auto assign 1 to 10
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Locale installer woks fine, it's clear from this output:
Cisco2911#sh telephony-service tftp-bindings
tftp-server flash:/its/russia_7921-dictionary.xml alias Russian_Russia/7921-dictionary.xml
tftp-server flash:/its/russia_7921-font.dat alias Russian_Russia/7921-font.dat
tftp-server flash:/its/russia_7921-kate.utf-8.xml alias Russian_Russia/7921-kate.utf-8.xml
tftp-server flash:/its/russia_7921-kate.xml alias Russian_Russia/7921-kate.xml
tftp-server flash:/its/russia_be-sccp.jar alias Russian_Russia/be-sccp.jar
tftp-server flash:/its/russia_g3-tones.xml alias Russian_Federation/g3-tones.xml
tftp-server flash:/its/russia_gp-sccp.jar alias Russian_Russia/gp-sccp.jar
tftp-server flash:/its/russia_ipc-sccp.jar alias Russian_Russia/ipc-sccp.jar
tftp-server flash:/its/russia_mk-sccp.jar alias Russian_Russia/mk-sccp.jar
tftp-server flash:/its/russia_gd-sip.jar alias Russian_Russia/gd-sip.jar
tftp-server flash:/its/russia_tc-sccp.jar alias Russian_Russia/tc-sccp.jar
tftp-server flash:/its/russia_td-sccp.jar alias Russian_Russia/td-sccp.jar
tftp-server flash:/its/russia_be-sip.jar alias Russian_Russia/be-sip.jar
tftp-server flash:/its/russia_rp-sccp.jar alias Russian_Russia/rp-sccp.jar
tftp-server flash:/its/russia_tags_file alias Russian_Russia/tags_file
tftp-server flash:/its/russia_utf8_tags_file alias Russian_Russia/utf8_tags_file
tftp-server flash:/its/russia_rtl-sccp.jar alias Russian_Russia/rtl-sccp.jar
tftp-server flash:/its/russia_g4-tones.xml alias Russian_Federation/g4-tones.xml
tftp-server flash:/its/russia_gh-sip.jar alias Russian_Russia/gh-sip.jar
tftp-server flash:/its/russia_gp-sip.jar alias Russian_Russia/gp-sip.jar
tftp-server flash:/its/russia_ipc-sip.jar alias Russian_Russia/ipc-sip.jar
tftp-server flash:/its/russia_mk-sip.jar alias Russian_Russia/mk-sip.jar
tftp-server flash:/its/russia_tc-sip.jar alias Russian_Russia/tc-sip.jar
tftp-server flash:/its/russia_td-sip.jar alias Russian_Russia/td-sip.jar
tftp-server flash:/its/united_states_7960-tones.xml alias United_States/7960-tones.xml
tftp-server flash:/its/russia_7960-font.xml alias Russian_Russia/7960-font.xml
tftp-server flash:/its/russia_7905-font.xml alias Russian_Russia/7905-font.xml
tftp-server flash:/its/russia_7960-dictionary.xml alias Russian_Russia/7960-dictionary.xml
tftp-server flash:/its/russia_7905-dictionary.xml alias Russian_Russia/7905-dictionary.xml
tftp-server flash:/its/russia_7960-kate.xml alias Russian_Russia/7960-kate.xml
tftp-server flash:/its/russia_7960-kate.xml alias Russian_Russia/7905-kate.xml
tftp-server flash:/its/russia_SCCP-dictionary.xml alias Russian_Russia/SCCP-dictionary.xml
tftp-server flash:/its/united_states_7960-font.xml alias English_United_States/7960-font.xml
tftp-server flash:/its/united_states_7960-font.xml alias English_United_States/7920-font.xml
tftp-server flash:/its/united_states_7960-dictionary.xml alias English_United_States/7960-dictionary.xml
tftp-server flash:/its/united_states_7960-kate.xml alias English_United_States/7960-kate.xml
tftp-server flash:/its/united_states_7960-kate.xml alias English_United_States/7920-kate.xml
tftp-server flash:/its/united_states_SCCP-dictionary.xml alias English_United_States/SCCP-dictionary.xml
tftp-server flash:/its/russia_7960-tones.xml alias Russian_Federation/7960-tones.xml
tftp-server flash:/its/vrf1/SEP60EB695EB160.cnf.xml alias SEP60EB695EB160.cnf.xml
tftp-server flash:/its/SEPDEFAULT.cnf alias SEPDefault.cnf
tftp-server flash:/its/vrf1/XMLDefault.cnf.xml alias XMLDefault.cnf.xml
I checked tftp debug log:
Jan 9 02:00:02.741: TFTP: Opened flash:/its/vrf1/SEP60EB695EB160.cnf.xml, fd 14, size 1443 for process 30
Jan 9 02:00:32.841: TFTP: Finished flash:/its/vrf1/SEP60EB695EB160.cnf.xml, time 00:00:30 for process 30
I also checked SEP60EB695EB160.cnf.xml file, it contains all apropriate info including Russian locale settings
What seems somewhat strange is that IPC experiences problems with getting SEP60EB695EB160.cnf.xml file - no idea why it happens because the config is really basic and the phone eventually gets its config (its number etc), so there must be another reason for the trouble with locale.
Any ideas?..
ā01-09-2012 02:38 AM
Did you try to remove all IPC cached configuration files from the PC where IP Communicator is installed on?
Carlo
ā01-09-2012 05:13 AM
Hi Carlo,
thank you for your answer!
How would one remove cached info?
I tried uninstalling initial version of IPC (7.0) and installing ver. 8.6, but it doesn't work either.
T.
ā01-09-2012 06:05 AM
Hi.
Try with settings Button , **# and then erase. on the IPC or delete all files in the following windows directory.
C:\Documents and Settings\"user"\application data\Cisco\Communicator\cache for xp
C:\Users\"user"\AppData\Roaming\Cisco\Communicator\cache for Windows 7.
Carlo
ā01-09-2012 06:35 AM
It's driving me mad.
Now, after starting IPC again (at hundrendth time) it received xml file and changed its locale even without having to clear cache. The only diffrence was that I placed my PC in local network rather than connecting it to LAN via VPN, as I did before.
What the h**l was going on??
Anyway, Carlo, thank you very much for your willingness to help!
T.
ā01-09-2012 06:46 AM
Hi.
You are welcome.
Just another tip.
Check the clock of your router and, if ok, create again CNF files under telephony service config.
Carlo
ā01-09-2012 07:38 AM
The thing is that the clock settings are OK, see the output:
Cisco2911#sh clock
19:35:29.211 MSK Mon Jan 9 2012
So no idea why telephony service doesn't take it into account, even after I make create cnf-files command. It also goes without saying that the command user-locale RU load CME-locale-ru_RU-Russian-8.8.2.3.tar automatically updates cnf files.
