IP Phone 6921 not register CUCM v8.6
Roni Apaza
Good day
I have a problem, my cucm has 73 registered model 6921 IP phones, but 12 model 6921 IP phones that do not register.
I have reset the Network and Security option; I also went back to delete it from the CUCM and returned it manually, but it still does not register. Please your support.
CUCM: Systemversion: 8.6.2.20000-2
IP Phone:
6921
         App Load ID: SCCP 9.2.1.0
         Boot Load ID: 0.0.0.14
In the ip phone log I see:
]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System
]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks 6.2
]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.8
]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-2005
CPU: TI TNETV1050 Communication Processor. Processor #0.
Memory Size: 0x2000000. BSP version 8.6.0.3.
Created: May 10 2011, 15:58:14
ED&R Policy Mode: deployed
Board : TI TNETV1050 Communication Processor
SOC : Titan, ChipId: 0x7, Version: 2
Cache : Write-Back, Write-Allocate
PSP Version : 8.6.0.3
Type : BasePSP 8.6.0.3
PSPWIZ Version : 0.6
MIPS freq : 162500000 Hz,
System Freq : 100000000 Hz,
VBUS freq : 81250000 Hz
BasePSP mode : Routing
Unable to delete route.
> WEB componment starting ...
> CFGTREE creating ...
CFGTREE creates finish.
syslog_init 423 server:
syslog_start (315) : syslog server is NULL
> L2PROTO reg to cfgmgr ...
> NETWORK reg to cfgmgr ...
cfgmgr_init : CFGMGR: Creating...
SSH: stop ssh server success!(sshd_start)
16:39:16, 05/10/2011 : system boot up (SCCP 9.2.1.0)
cdpInit: init ok.
> MMI: Creating Browser ...
ed75752 GLCD: bpp:8, X:396, Y:162 paletteSz:512
uglTitanModeSet 485:pGenDriver->fbAddress b5441700
appCreate: autoBootLevel=2
MXP environment is created.
About to create Idle Task
About to create Measurement Task
Idle Measurement Tasks created
Panic button enabled
Heartbeat started
Creating Golden Gateway application...
TNETV1050 Communication Processor Revision: PG3.1
DSP core type (TITAN)
dimhw_HALT_DSP - No TDM config needed
Retrieving DSP image
Source: Flash file system, file: /DSP/DSP69xx.0-0-0-8.zz
unzip 7-ZIP file successful
purchd_start(). ok.
** VOIP IPP firmware SCCP 9.2.1.0 **
** compiled on May 10 2011 at 15:58:01 **
VxWorks login: 0000001636 - Network: nw_create() ipstack_mode=2
16:39:18, 05/10/2011 : Network: nw_create() ipstack_mode=2
0000001637 - Following features compiled out of the build:
0000001637 - DIM_DNLD_PAGED_BOOT
0000001637 - DIM_DNLD_DIRECT
0000001637 - DIM_DNLD_MSG
0000001637 - DIM_CHAN_IF
0000001637 - DIM_RTCP_IF
0000001637 - DIM_SIG_IF
0000001637 - DIM_AUDIO_IF
0000001637 - DIM_LOMGR_CHN_FIFO
0000001637 - PROTO_AAL2
0000001637 - PROTO_CLRDT
0000001637 - PROTO_MODEM
0000001637 - DIM_3PROC
0000001637 - DIM_DETAILED_SPY
0000001637 - DIM_HI_PRIORITY_MSGS
0000001637 - Following features not defined in build and have been enabled
0000001637 - by default; REVIEW to remove potential unnecessary code:
0000001637 - All features are accounted for!!!
0000001640 - ROOT: Hardware ringer :FALSE
16:39:18, 05/10/2011 : ROOT: Hardware ringer :FALSE
0000001651 - CMM: cmm_create(). num_tcids=2. max_rtp_term=4
0000001653 - ROOT: CMM created
0000001655 - ACCU: Creating...
0000001655 - ACCU: Created.
0000001655 - TSTN> tMVX_TSTN creating...
0000001656 - SAPP : initializing sockets
0000001657 - SAPP : initializing calls
0000001663 - SAPP : initializing sccp
0000001663 - SAPP : initialized
0000001663 - TSTN> tMVX_TSTN created.
0000001664 - CUVA> tMVX_CUVA creating...
0000001664 - CUVA> tMVX_CUVA created.
0000001669 - NMflash_geM: Build contains Onlyt TUIU
_font0000001696 - DSPALLOC: AER instance 1, max_tail = 60 ms, usage = ( HS HeS GL_HS G
_HeS )
0000001696 - DSPALLOC: AER instance 0, max_tail = 200 ms, usage = ( HS HeS HF GL_HS G
_HeS )
0000001703 - ACCU: accu_init(). change accu state. normal->normal
0000001703 - TCP : SNET task started ...
0000001703 - SCCP : SCCP task started...
0000001703 - CUVA> 'acuva_init_sock()'. initializing...
1310000001704 - CUVA> 'acuva_init_sock()'. non-block CUVA sock-port(13:4224), initialized
:0000001737 - DIM: 0:*,Writing 0x6a001400 @ 0x100
/FONT/rtl-sccp.jar open fail.
font_conf_init 95: error font file
0000001844 - DSPA: DSP 0,Image 0:Download done!
0000001844 - NMM: DSP Download OK
0000001846 - NMM: 0, Set Channel State UNCONFIGURED Done (SUCCESS)
0000001869 - NMM: 1, Set Channel State UNCONFIGURED Done (SUCCESS)
0000001869 - NMM: 0, Channel Config Done (SUCCESS)
0000001884 - NMM: 0, Set Channel State NORMAL Done (SUCCESS)
0000001894 - NMM: 1, Channel Config Done (SUCCESS)
0000001924 - NMM: 1, Set Channel State NORMAL Done (SUCCESS)
rwxrwxrwx 0:0 a: -1 i:0 May 10, 2011 4:39:18pm 227 Chirp1.raw
rwxrwxrwx 0:0 a: -1 i:0 May 10, 2011 4:39:18pm 502 Chirp2.raw
xml_config_keymap(1367): -----
deck: stemplate
card: template
href: #stemplate?template
xml_config_keymap(1372): -----
lldp: l2lldp_get_cfg failed!
cdpTxTask 2779 port[sw]: 0 2
lldp: init OK
0000002715 - AMMU: ammu_proc_cfgmgr_msg(). msg_id = 27(cfgmgr_ip_release)
0000002715 - AMMU: ammu_cfgmgr_send_app_msg(). msg=signal_unreg_ready
0000002722 - AMMU: ammu_proc_cfgmgr_msg(). msg_id = 36(cfgmgr_mmi_init_ready)
cdpTxTask 2779 port[sw]: 0 1
cdpTxTask 2779 port[sw]: 0 0
0000007726 - AMMU: ammu_proc_cfgmgr_msg(). msg_id = 22(cfgmgr_l2proto_state_change)
0000007726 - AMMU: ammu_cfgmgr_send_app_msg(). msg=signal_unreg_ready
0000007743 - AMMU: ammu_proc_cfgmgr_msg(). msg_id = 27(cfgmgr_ip_release)
0000007744 - AMMU: ammu_cfgmgr_send_app_msg(). msg=signal_unreg_ready
The DUT in DHCP Bind state.....
default 192.168.8.1 done
16:39:37, 05/10/2011 : SEPe8b74858481f Get ip from DHCP server : 192.168.8.177
0000011567 - AMMU: ammu_proc_cfgmgr_msg(). msg_id = 9(cfgmgr_activate)
rwxrwxrwx 0:0 a: -1 i:0 May 10, 2011 4:39:38pm 1825 local
rwxrwxrwx 0:0 a: -1 i:0 May 10, 2011 4:39:38pm 5593 config
Copying files to flash... Complete.
..ew_ip_change 3267 old ip_addr=, new ip_addr=192.168.8.177
0000013400 - AMMU: ammu_proc_cfgmgr_msg(). msg_id = 28(cfgmgr_ip_change)
0000013400 - AMMU: ammu_cfgmgr_send_app_msg(). msg=signal_unreg_ready
EW: ew_client_task_create fail, either domain is null or invalid!
provision_http_download_file 1094: ERROR in dowloading file
0000013792 - Idle/Max KIPS: 10923 / 150501 --- MIPs avail: 10.92 CPU Idle: 7.26%
ERR [TFTP] tftpSend:442: Transfer Timed Out.
ERR [TFTP] tftpGet:1019: File transfer error.
0000019629 - AMMU: ammu_proc_cfgmgr_msg(). msg_id = 34(cfgmgr_download_fail)
0000022647 - AMMU: ammu_proc_cfgmgr_msg(). msg_id = 34(cfgmgr_download_fail)
0000030682 - AMMU: ammu_proc_cfgmgr_msg(). msg_id = 34(cfgmgr_download_fail)
5 Replies 5
Jaime Valencia
There are a lot of TFTP errors, start by making sure the config files are there, and the phone can reach them.
java
if this helps, please rate
I checked again and the configuration is in the CUCM. Several months ago these phones were registered, but they were disconnected and saved, now that we have reconnected them they do not register.
Hi Jaime
Checking, in the CUCM (Cisco Unified Serviceability), I see that the TFTP service is "active", but "not running". I try to start it, but it stays the same.
Any idea?
