IP phone 7937G
sorinbadea
How to add a 7937G ip phone to the call manager version 6.0.1.2000-3. It is not on the list when I go to Device - Phone - Add new - Phone type
Thanks.
Read once again my post, i said "device pack" NOT "service pack". They're not the same thing and shouldn't be confused.
CSCsq39150            Bug Details
Cannot find polycom 7937 phones in CUCM phone create menu
Symptom:
polycom 7937 phone not showing in phone create  menu
Conditions:
CUCM 6.0 or earlier
Workaround:
Install latest dev pack : phone was added in following packages
4-1-DevPack-59
4-2-3DevPack-36
4-3-1-DevPack-16
5-1-2-3111-1
5.1.3.2104-1
6-0-1-2111-1
There is no other way, if you want to use the 7937 you NEED to install the devpack, which requires a cluster reboot as it will add support for new models.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
Install the latest device pack for your CUCM version and then look in the list again
java
java
sorinbadea
Thank you for the answer.
Installing a service pack may or may not have implications to other systems, like Unity or UCCX. I am looking for a different solution, if there is one available.
Symptom:
Conditions:
CUCM 6.0 or earlier
Workaround:
4-1-DevPack-59
4-2-3DevPack-36
4-3-1-DevPack-16
5-1-2-3111-1
5.1.3.2104-1
6-0-1-2111-1
java
java
Thank you.
