05-12-2016 03:04 AM - edited 03-17-2019 06:52 AM
Hello
I have To sip Server with a different IP address.
one account on first server register and work correctly.
but second account on other server dont register.
how can I register 2 account in 2 different server ?
Thanks.
05-12-2016 04:12 AM
Is this CUCM/CUE or 3rd party SIP server?
05-13-2016 02:15 AM
I have 2 Asterisk SIP Server.
05-13-2016 02:24 AM
Ok, so you want the phone to register to two sip servers?
05-13-2016 02:27 AM
yse
One Line is register but other not Registre
05-13-2016 02:40 AM
If you let the phone register one SIP server at a time, can the phone register to the 2nd Asterisk box using the same credentials?
05-16-2016 10:38 PM
each account can register separated on the server.
but when I want to register 2 account at the same time, only first account register and other account don`t register.
Exp:
first account is :
User Name : 101 , Pass : 101 , IP : 192.168.60.1
Second account is :
User Name : 201, Pass : 201 , IP : 192.168.50.1
05-17-2016 01:01 AM
Point a web browser to the IP address of the phone. Go to Network Setup. What are the values of CUCM Server 1 and CUCM Server 2?
05-17-2016 07:18 AM
My Server's protocol is SIP not CUCM.
Server is elastix.
05-17-2016 02:24 PM
It doesn't make any difference. What are the values of CUCM Server 1 and CUCM Server 2?
05-20-2016 07:35 AM
I can not go to phone web panel.
05-20-2016 06:29 PM
On the phone do the following:
Settings > Device Config > Unified CM Configuration > Unified CM 1
What are the values of Unified CM 1 & Unified CM 2.
05-31-2016 12:53 AM
