Interopt between VWIC2 and VWIC3
zarni tun
Hi Anyone,
One site is C2811 with VWIC2-2MFT-T1/E1 and other site is C9211 with VWIC3-2MFT-T1/E1.
There is any interoperability issue between these two cards, and in this scenario?
Hello Zarni, I don't think that we find such reference Cisco doc because here we are having these cards on separate routers and both work independently.
Are you having any issue with this scenario ?
Suresh
5 Replies 5
Suresh Hudda
Nope, There should not be any issue.
Suresh
Hi Suresh Kumar,
Thanks for your quick response. Do you have any reference document, please.
Suresh
Hi Suresh.
Thanks for your reply.
No issue yet, just at planning stage.
If so the only thing I can do is just comparing the product data sheets and highlight the difference.
Yes, you can just highlight the difference.
Suresh
