IP Phone 8945 web information - network info not accurate
I'm often using IP Phone web interface to debug connectivity problems.
In the Network Statistics -> Network page, I suppose we see the real speed the ports are running, and the refresh is immediate upon change.
But what are the informations displayed in Network Setup ? It seems they are not accurate
SW Port Remote Configuration
PC Port Remote Configuration
SW Port Setup
PC Port Setup
I'm running 8945 with fw 9-3-2-11 and only LLDP is activated on Catalyst 2960, not CDP.
For testing I've set the Catalyst port to 100 Full forced and the PC NIC is auto. In the Network info we see the real speed after the changes. However in the network setup - even after phone reset and phone power off / on - we see Auto Negociate for the 4 fields listed above. True for the PC NIC but false for the catalyst port.
Is this something not implemented yet or a bug ?
JC
I've seen at least 2 bugs concerning Web informations
CSCug69210 8945 SCCP firmware reporting incorrect jitter during video calls
CSCue56980 On the phone webpage, timezone field shows as NONE
Difficult to trust it then...
