IP Phone Cisco 7925G with SIP Server
mariokaufmann
Hi, what does I need for use a Cisco 7925G with a SIP Server?
Mario
5 Replies 5
Manish Gogna
Hi Mario,
Please explain your requirement in detail as it is not clear. Most of the information related to 7925G deployment are given here
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cuipph/7925g/7_0/english/deployment/guide/7925dply.pdf
Manish
Hi Manish
Thanks for your answer. I did a mistake: I don't mean SMTP, I mean SIP. I have from my provider this information (see below) for setup my VOIP-Phone. But in the settings from Cisco 7925G I can't setup this information. How can I do, for use this phone with SIP?
SIP Zugangsdaten
SIP-Server: sip.green.ch
SIP-Serverport: 5060
SIP-Username: XXX
Passwort: XXX
7925 does not support SIP protocol. Please check the datasheet
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-wireless-ip-phone-7925g/data_sheet_c78-504890.html
Manish
Hi Manish
Thanks for your answer. Also not with a Cisco SPA112 Phone Adapter?
Mario
What is the call server?   I am suspecting it is NOT Cisco-branded.  If the call server is Asterisk then you'll need to look at chan-sccp-b.
