IP Phone Couldn't register with Call manager
Andrewkai
I'm currently running for one voice project. Gateway and call manager are up and running. I can make call out by using soft phone.
But I have a problem with IP Phone registration with my call manager.
It shows Configuration IP and nothing came out after that. Could you please help me?
Sincerely,
Andrew
2 Accepted Solutions
which device is acting as DHCP server for the IP phones ?.you have give option 150 with secondaryCUCM ( Cucm IP address>
Sanel
Andrew,
what is the tftp server for ip phones? you should set tftp server to gateway router if your gateway is doing dhcp.
Hope this help..
PK
5 Replies 5
mohamed-sanel
Hello
The phones are in centralized site or distributed one ( means connected over WAN ) ?
Any error message on the phone .
Sanel
Thanks for your reply Sanel!
The phone are connnected between LAN. The problem is that ip phone are getting firewall ip address as tftp server 1 ip.
Sincerely,
Andrew
Sanel
Andrew,
Hope this help..
PK
Thank you guys! After changing tftp server ip to gateway router. My ip phones can register with CCM
Cheer!
Andrew
