10-21-2020 04:27 AM
Hello everyone, can I register the Cisco Unified IP Phone CP-7861, in a SIP server?
10-22-2020 09:24 AM
Yes, the topic has been discussed many, many, many times at the forum, did you review any of those threads?
Start by finding out if your device is running enterprise FW or 3PCC FW to determine which threads would be applicable as the configuration is very different depending on which FW you use.
10-29-2020 08:39 PM
Hello, the device is using the FW 3PCC, I have searched the forum but I find that they talk about an .xml file.
10-30-2020 08:45 AM
Then the phone has a config GUI in which you will need to fill in all the details so it registers to your PBX
11-02-2020 07:56 PM
Hello Jaime Valencia, a query, if the IP phone is in enterprise service mode, what is the procedure?
11-03-2020 07:08 AM
Provide all the configuration in the configuration files in the same .xml format as the phone would get them from CUCM.
