Cancelled incoming call keeps ringing on voip phone.
Frank Hoeben
Hello all,
I have an odd issue with inbound calls through a SIP trunk via CUBE to our CUCM.
Calls that are cancelled before the phone has been picked up keep ringing until the phone has been picked up. Of course that results in a disconnect as the other call leg has been cancelled already.
Found the cause after looking through the logs.
Because we rewrite the header on INVITE the call-leg could not be cancelled properly.
The solution was to rewrite the header for CANCEL in the same way.
For others who might hit this page through a google search, the error was:
SIP/2.0 481 Call Leg/Transaction Does Not Exist
Solution:
voice class sip-profiles 1
 request INVITE sip-header To copy "sip:(.*)@" u01
 request INVITE sip-header SIP-Req-URI modify ".*@(.*)" "INVITE sip:\u01@\1"
 request CANCEL sip-header To copy "sip:(.*)@" u01
 request CANCEL sip-header SIP-Req-URI modify ".*@(.*)" "CANCEL sip:\u01@\1"
Can you capture a debug ccsip messages and post that along with the trace file of the node the phone is registered to?
Maren
Solution:
Thanks for posting your solution. That is helpful for folks who will be looking at this later!
