Ip phone CTL query
Gowrishankar NC
Hi Guys,
If I migrate the phones from cucm 8.6 with cluster security mode 0 to cucm 10.5 with cluster security mode 0 will it cause any issues with ip phone registration?? Like i need to delete CTL/ITL files from phones.
Gowrishankar
Deepak Rawat
CTI will not be a problem since both the clusters are running in non-secure mode but you will definitely need to take care of ITL. Refer below post that talks about this and the steps involved in the same:
https://supportforums.cisco.com/document/60716/migrating-ip-phones-between-clusters-cucm-8-and-itl-files
Deepak
Hi Deepak,
Thanks for the update and link.
Gowrishankar
Jaime Valencia
You don't need to worry about CTL, but you do need to worry about ITL as that's enabled by default on 8.x+
java
if this helps, please rate
