12-01-2010 02:03 AM - 편집 03-16-2019 02:12 AM
I have a client who's ip phone installed with two 7915 expansion module on it, however after he plug in the power for them all the buttons on both 7915 turned red. What does it mean and how to solve it?
날짜: 12-01-2010 02:40 AM
Hello Ken,
We will need some more information to better understand the issue:
* On which phone model did you install the 2 expansion modules 7915?
* Which firmware version is this phone running?
* Is the phone+expansion module registered on CME or CM? Which version of CME/CM?
* Does it work if you only install one 7915 expansion module?
I found this document for CME where it says:
http://tools.cisco.com/squish/ef2d2
Cisco Unified IP Phone 7915 Expansion Module:
To support a 7915 or 7916 expansion module, IP phones must have firmware 8-3-5 or a later version. The 7915 and 7916 expansion modules are supported only on the 7962, 7965, and 7975.
German
날짜: 12-01-2010 06:56 PM
CP-7962
8.5(3)
CME, version 7
Not yet tried
날짜: 12-01-2010 07:52 PM
Hi Ken, Does the CME has the sencond expansion module configured?
#ephone 6
mac-address XXXXX
type 7962 addon 1 7915 2 7915
hth
David
날짜: 12-01-2010 08:06 AM
Has the phone been configured for use with the sidecar? As mentioned above, is the phone even compatible with the sidecar? IIRC a phone either deleted in CUCM or not configured for the sidecare will result in the sidecar line buttons lighting up all red.
날짜: 02-18-2014 06:35 AM
I have a similar issue: CP-7962, CUCM 8.6, firmware is 9.3.1, SCCP.
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
