12-10-2008 07:45 AM - edited 03-15-2019 03:00 PM
I have a 7941 IP Phone newly installed. It worked well for three days and afterwards, when a call (Internal or External) is placed to or from the phone I hear a funny "crack crack crack" noise. I tried replacing the ethernet cable and also did a factory reset on the phone but the problem persist. Could this be a phone problem? Please help.
12-10-2008 07:56 AM
Since this is not normal and you do the basic troubleshooting, should apply for a replace of decive (RMA).
12-10-2008 09:23 AM
Do you hear the noise on the speaker phone or through the handset? If the later try replacing just the handset and cable, or try using a headset instead. Still the same?
If the sound is coming through the speaker phone, then it is likely the phone itself is faulty and RMA will be necessary.
If you connect the phone to another network point and the problem moves with the phone, then at least you know the problem is definitely the phone.
Hope this helps.
Allan.
