06-23-2014 01:54 PM - edited 03-16-2019 11:11 PM
when users logout their Device profile of the phone , the phone still rings
is there any option to disable this or stop ip phones ringing after user UDP logout
thanks
shurufade
06-23-2014 03:02 PM
If the DN that the device has when no EM is logged in, is reachable by users, it will ring, nothing to do there.
Create a separate UDP and assign it to the devices as the logged out profile and use a DN no one will dial.
06-24-2014 01:38 AM
Thank you the update jaime
however let me clarify this bit more, I have a branch with 6 users who are logged on to their ip phones .. where their line group is set as broadcast(see screenshot) which means that their phones will ring simultaneously right.
so what i am looking for is that when two users log out from their phones . i just want to ring the remaining 4 phones not all the phones
so will there be a box to untick in CUCM hunt to avoid logged out phones from ringing
hope that helps
let me know what you think
thanks mate
06-24-2014 05:18 AM
Hi Shurufade.
What you can do is put the logged out phone's DN into a different partition of UDP's DN.
Carlo
06-24-2014 05:24 AM
Have you tried giving the users the HLOG key? They can log out the hunt group prior to logging out their UDP. You should also consider what Carlo & Jaime (+5) have recommended.
Yosh
