VG224 SCCP registartion
HelloFor VG 224, How much it take to SCCP to go register from the first CUCM to the second CUCM ( and the to the third CUCM) when the first is down. Thank you
I can see on the gateway that transcoding resources are being used with the command "show dspfarm all". Now I would like to find out any identifying information about the calls needing transcoding, so I can figure out why they need it.Is there any co...
Hey,Hope I can find someone who has experienced issues similar to what i have experienced.I had 2 clients who are using CME and I moved them onto SIP with a Watchguard Firewall. Outgoing calls always work find but inbound calls have always been an is...
Dear all,we've had a case of a SIP 8961 Phone rebooting during a phone call.Could you help me interpret, from the logs below, what actually happen. Particularly if is it a Firmware Problem or a network connectivity issue?1) User made a phone call @ 1...
How can i gain access to uc migration section
Hello all,I've done some 8.5 upgrades to 9.1 so I'm quite familiar with the refresh upgrade process and the additional server downtime vs. say and 8 to 8.5.On reading the upgrade guide for CUCM 9.1(1), I stumbled across this line on page 5 -"You cann...
Hi,I have upgraded from 6.1 to 9.1 successfully by restoring 6.1 complete data, In Enterprise parameter in PHONE URL PARAMETERS sections i see that instead of publisher IP there is subscrber IP, and the subcriber i have already deleted from the publ...
Hello,I have deployed Unity Connection 9.1 with the UK English locale selected as the system default and the specific language for all users.When a user selects option 4 for setup options then 1 for during for greetings they are then prompted to ente...
I'm trying to find out if there are any differences between a Cisco 9951 and a 9971. I need to get some camera phones for my home lab for CCIE Collaboration. The 9951 is half the price of the 9971. The only difference I've found online is that a 9...
Hello, I've been experimenting with CUCI-Lync, it seems to be working OK with one exception. Off-hook/on-call status is never being reflected in the Lync client. I'm sure there's something I need to enable to make that happen, but I'm not seeing i...
Hi ;I want to connect a UC520 with Pansonic tda600 using KX-TDA0490 VoIP card.Are these compatible . Any special configuration required on either side ? Any sample config ?Thanks in advance
I am trying to connect a 9971 over a VPN tunnel back to my call manager. I have a wide open tunnel back to my end. I have to open up ports on the firewall that is in front of call manger. I have tftp and sip opened up. I can see the the phone tr...
Hello,We are in process of installing CUCM 9.1.2.10000-28 & Unity Connection 9.1.2.10000-28 on UCS.CUCM Installed successfully but Unity connection failed in synchronising NTP.I am using same NTP Server for Unity Connection which i used for CUCM.Can ...
Subject | Author | Posted |
03-22-2023 02:46 AM | ||
03-21-2023 12:05 PM | ||
03-21-2023 09:21 AM | ||
03-21-2023 09:15 AM | ||
03-19-2023 11:06 AM |
User | Count |
13 | |
8 | |
8 | |
4 | |
1 |
