10-18-2019 06:30 PM - edited 10-29-2019 11:46 PM
Hi erverybody.
I´m configuring a ISR 4321 and when I test softphone registration from other branch via VMVPN I can´t get full register. I do a debug tftp events and tftp packets command and see following:
Oct 19 01:18:25.639: TFTP: Server request for port 20713, socket_id 0x7F0D55224AA8 for process 425
Oct 19 01:18:25.639: TFTP: read request from host 201.141.38.15(20713) via Tunnel0
Oct 19 01:18:25.639: TFTP: Looking for CTLSEP00FFEE0262D3.tlv
Oct 19 01:18:25.639: TFTP: Sending error 1 No such file
Oct 19 01:18:32.094: TFTP: Server request for port 20713, socket_id 0x7F0D5E3344A0 for process 425
Oct 19 01:18:32.094: TFTP: read request from host 201.141.38.15(20713) via Tunnel0
Oct 19 01:18:32.095: TFTP: Looking for SEP00FFEE0262D3.cnf.xml
Oct 19 01:18:32.105: TFTP: Opened flash:/its/vrf1/XMLDefault7962.cnf.xml, fd 4, size 1230 for process 425
Oct 19 01:18:32.105: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x7F0D5E3344A0
Oct 19 01:18:36.106: TFTP: Sending block 1 (retry 1), len 512, socket_id 0x7F0D5E3344A0
Oct 19 01:18:41.107: TFTP: Sending block 1 (retry 2), len 512, socket_id 0x7F0D5E3344A0
Oct 19 01:18:45.614: TFTP: Server request for port 20713, socket_id 0x7F0D45492210 for process 534
Oct 19 01:18:45.614: TFTP: read request from host 201.141.38.15(20713) via Tunnel0
Oct 19 01:18:45.614: TFTP: Looking for CTLSEP00FFEE0262D3.tlv
Oct 19 01:18:45.615: TFTP: Sending error 1 No such file
Oct 19 01:18:47.106: TFTP: Sending block 1 (retry 3), len 512, socket_id 0x7F0D5E3344A0
Oct 19 01:18:52.104: TFTP: Server request for port 20713, socket_id 0x7F0D45492400 for process 534
Oct 19 01:18:52.105: TFTP: read request from host 201.141.38.15(20713) via Tunnel0
Oct 19 01:18:52.105: TFTP: Looking for CTLSEP00FFEE0262D3.tlv
Oct 19 01:18:52.105: TFTP: Sending error 1 No such file
Oct 19 01:18:54.106: TFTP: Sending block 1 (retry 4), len 512, socket_id 0x7F0D5E3344A0
Oct 19 01:18:59.887: TFTP: Server request for port 20713, socket_id 0x7F0D45492400 for process 534
Oct 19 01:18:59.887: TFTP: read request from host 201.141.38.15(20713) via Tunnel0
Oct 19 01:18:59.887: TFTP: Looking for CTLSEP00FFEE0262D3.tlv
Oct 19 01:18:59.887: TFTP: Sending error 1 No such file
Oct 19 01:19:02.106: TFTP: Finished flash:/its/vrf1/XMLDefault7962.cnf.xml, time 00:00:30 for process 425
Oct 19 01:19:06.333: TFTP: Server request for port 20713, socket_id 0x7F0D5E0B6058 for process 425
Oct 19 01:19:06.333: TFTP: read request from host 201.141.38.15(20713) via Tunnel0
Oct 19 01:19:06.333: TFTP: Looking for CTLSEP00FFEE0262D3.tlv
Oct 19 01:19:06.333: TFTP: Sending error 1 No such file
Oct 19 01:19:12.780: TFTP: Server request for port 20713, socket_id 0x7F0D5E0B6058 for process 425
Oct 19 01:19:12.780: TFTP: read request from host 201.141.38.15(20713) via Tunnel0
Oct 19 01:19:12.780: TFTP: Looking for CTLSEP00FFEE0262D3.tlv
Oct 19 01:19:12.781: TFTP: Sending error 1 No such file
Oct 19 01:19:19.737: TFTP: Server request for port 20713, socket_id 0x7F0D5E0B6058 for process 425
Oct 19 01:19:19.737: TFTP: read request from host 201.141.38.15(20713) via Tunnel0
Oct 19 01:19:19.737: TFTP: Looking for CTLSEP00FFEE0262D3.tlv
Oct 19 01:19:19.737: TFTP: Sending error 1 No such file
Oct 19 01:19:26.199: TFTP: Server request for port 20713, socket_id 0x7F0D5E0B6058 for process 425
Oct 19 01:19:26.199: TFTP: read request from host 201.141.38.15(20713) via Tunnel0
Oct 19 01:19:26.199: TFTP: Looking for SEP00FFEE0262D3.cnf.xml
Oct 19 01:19:26.220: TFTP: Opened flash:/its/vrf1/XMLDefault7962.cnf.xml, fd 4, size 1230 for process 425
Oct 19 01:19:26.221: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x7F0D5E0B6058
Oct 19 01:19:30.221: TFTP: Sending block 1 (retry 1), len 512, socket_id 0x7F0D5E0B6058
Oct 19 01:19:35.221: TFTP: Sending block 1 (retry 2), len 512, socket_id 0x7F0D5E0B6058
Oct 19 01:19:41.221: TFTP: Sending block 1 (retry 3), len 512, socket_id 0x7F0D5E0B6058
Oct 19 01:19:48.221: TFTP: Sending block 1 (retry 4), len 512, socket_id 0x7F0D5E0B6058
Oct 19 01:19:56.222: TFTP: Finished flash:/its/vrf1/XMLDefault7962.cnf.xml, time 00:00:30 for process 425
Phone can open and finish XML Default cnf.xml but can´t open CTLSEP00FFEE0262D3.tlv. If I try locally phone can registering.
This same behavior occurs with other phones within the branch where you can open the conf.xml file but cannot open the tlv
Attached config.
Can anybody help me?
Regards.
Solved! Go to Solution.
11-01-2019 05:59 PM
Thanks for help.
The issue was that SIP register global needed authenticate register because phones and CME are in different subnet.
Here copy link to help me:
Thanks.
10-21-2019 02:20 AM
10-29-2019 08:50 AM
Hi friend. Thanks for your answer.
Yes, the file exist. What seems strange to me is that it opens fila and ends the process and stays in a loop loading the file. In fact, it happens to me with local phones also now.
10-21-2019 02:26 PM
10-29-2019 08:51 AM
Hi friend, thanks for your answer.
The tftp server is reachble without nat. What seems strange to me is that it opens file and ends the process and stays in a loop loading the config file. In fact, it happens to me with local phones also now.
10-30-2019 02:50 PM
10-31-2019 10:37 PM
Hi Adams...
Already I tested this and nothing.
Thanks for reply.
11-01-2019 04:35 AM
11-01-2019 05:59 PM
Thanks for help.
Thanks.
