IP Phone registration over VPN CUCM Sandbox 12.5
Hi all,
in order to do some testing, we'd like to connect to the CUCM Sandbox 12.5 via VPN.
Can you please let me know which Cisco Phones we have to order for it?
We've found the following: SPA525G2 (https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/spa525g2-5-line-ip-phone/data_sheet_c78-603725.html)
Would you recommend this or another model?
Thanks a lot in advance for your support!
Best regards,
Thomas
That's a question for whoever manages the sandbox and the VPN
java
if this helps, please rate
Jaime Valencia
SPA phones are not natively supported on CUCM, so you would need to configure them as SIP 3rd party endpoints and get a limited set of features.
If you want a phone that is natively supported, see here:
https://www.cisco.com/c/dam/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-7940g/prod_brochure0900aecd800f6d4a.pdf
If you want to keep on using it, and don't worry about EOS/EOL, your best option are the 78xx/88xx series
java
Hi Jaime,
Thank you very much for prompt response - this is very helpful!
Best regards,
Thomas
Hi again,
I just talked to my colleague from dev team.
He told me, that he's able to connect to the sandbox via VPN just with ONE device/computer at the same time.
But for our testing we have to establish at least two simultaneous connections at the same time.
Do you know if it's possible to setup more than one parallel connections or is it an unchangeable restriction of the sandbox, that only allows one connection at a time?
Best regards,
Thomas
java
