IP Phone Rejected on Subscriber
nithin louis
I have an IP Telephony setup with Publisher and Subscriber ver. 9.1.
I created a new Call mager group and have Subscriber higher than my Publisher in my CM group.
Reloaded phones and they re-registered to the Publisher.
For testing the DB replication I have added a end user in subscriber and its reflecting on publisher also.
I checked all the services are up and running in 2 nodes.
I disconnected my Publisher from the network and my phones did not even re-register and its showing in the subscriber as REJECTED.
Earlier i auto registered all the phonoes through publisher and now auto registration is disabled on both the nodes.
Please help to resolve the issue.
Thanks in Advance......
Nithin Louis...
25 Replies 25
Hi Nithin,
Can u share what all u have configured in Windows server for DHCP?
regds,
aman
Hi Aman,
We created 3 scopes in the windows DHCP server.The scopes are starting from 192.168.30.x,192.168.31.x,192.168.32.x.
For example if we consider the scope for 192.168.30.x.
Excluded IP address are 192.168.30.1 to 192.168.30.25
Starting IP address 192.168.30.1  and ending ip addess 192.168.30.225
Default Gateway 192.168.30.1
TFTP server 1 option 150 192.168.30.20
TFTP server 2 option 150 192.168.30.24
we followed the following document for configuring the Windows DHCP.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800942f4.shtml
Thanks & Regards
Nithin Louis.
Hi Nithin,
Try doing packet capture by making DHCP enable on phones
https://supportforums.cisco.com/docs/DOC-11599
what is the firmware of ip phones?
regds,
aman
HI Aman,
I restart the publisher from CLi after that  all the SCCP phones are registered in Subscriber but 8961 phnes are not registering.
Now all the phones are in default device pool and publisher is upper than subscriber....
8961 phones are registering when the publisher came up.I have done factory reset for one 8961 phone but no luck.
Thanks & Regards
Nithin Louis.
Nishant Savalia
Level 4
Level 4
Ok..What about the recheability from DHCP server to subscrber and vice versa?
If recheability is fine then please try below procedure:-
1). Stop the publisher services.
2). Stop the subscriber services.
3). Activate the publisher services
4). Activate the subscriber services.
Please maintain the sequence. And if the activity is service affecting then please perform it in low busy hour (night).
Also please try to capture registration process through wireshark and RTMT both.
Regards, Nishant Savalia
nithin louis
Any update guys....?
Nithin
jlukemorgan
Do you have the CM Group defined so that the Device pool with the phones is served by both your Pub and Sub?
-Luke
Hi Luke,
I have default Call mager group in that Publisher is upper than Subscriberand assigned to default device pool and all the phones are registered in the default device pool.
As i mentioned earlier restart the publisher from CLi after that  all the SCCP phones are registered in Subscriber but 8961 SIP phnes are not registering.
Thanks & Regards
Nithin Louis.
Are the pub and sub separate or are they common on the same VLAN?   Are you using DNS/hostnames in your configs or purely going IP?
Your SCCP phones are failing over properly and only your SIP phones won't reg w/ the sub?
How are your phone VLANs separated from your cluster?   Any firewalls or routers between them?
Hi Luke,
I have renamed the hostaname to Ip address in the Enterprise parameter and it working fine.
Nithin Louis.
Hi  Nithin,
thanks for rating.
regds,
aman
