02-09-2015 08:29 AM - edited 03-17-2019 01:54 AM
hello, everybody!
need assistance.
I have CUCM 9.1 with demo licences.
I have some phones - 7911 and 6921 - registered.
I have enabled Web Access feature on all phones.
but don't have web access.
any suggestions?
Solved! Go to Solution.
02-10-2015 02:20 AM
Hi Sergey,
I overlooked it when webaccess is enabled I see <webAccess>0</webAccess> when it is disabled><webAccess>1</webAccess>. So for your case webaccess = 0 is good, that means it's enabled.
Can you ensure you have right device pack installed which is compatible with your phone firmware.
Check below link for more details
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix_chapter_01.html
HTH,
Mohammed Noor
02-09-2015 05:36 PM
Hi Sergey,
After enabling Web Access you need to reset the phone, Did you reset the phone ?. Go to Setting -> Device Configuration -> Web Access Enabled is Yes.
HTH,
Mohammed Noor
02-09-2015 11:04 PM
Hello, Mohammed!
Well, yes. I have resetted phones many times. I have found an interesting thing. I cannot connect by web to 6921 and 7911. but on the same CUCM I have 9951. and I can connect to it by web.
02-10-2015 12:14 AM
Hi Sergey,
Try using different web browser. Can you provide 6921 and 7911 phone's phone config file
Command below "tftp 1.1.1.1 get SEP<MAC Address>.cnf.xml
Mohammed Noor
02-10-2015 01:44 AM
02-10-2015 01:53 AM
Hi Sergey,
Looks like you have applied config on Common Phone Profile and configuration applied on phone tftp config file. can you enable web access on phone configuration page and check it that works.
Per the Config file its "0", which means disabled.
HTH,
Mohammed Noor
02-10-2015 02:00 AM
02-10-2015 02:20 AM
Hi Sergey,
HTH,
Mohammed Noor
02-11-2015 02:00 AM
Mohammed, thanks a lot!
there were problems with updating of firmware (had to reset phones).
but after upgrading web-access is working.
thank you once more.
Sergey
02-11-2015 02:02 AM
I am glad i was of some help. :-)
Thanks and Regards,
Mohammed Noor
