IP phones time sync issue
ndsivaguru
We have CUCM PUB & SUB. IP phones registered in SUB shows correct time. PUB registered phones shows 1 hr lagging. I checked the NTP servers, it working fine. Any idea.?
Each same model and version is 9.1.2.10000-28
Sivaguru D
7 Replies 7
Aman Soi
Hi Siva,
was this working earlier fine? any change u did like changing NTP
Is this happening with specific IP phone model  ?
can u share output of utils ntp status from PUB and SUB?
regds,
aman
Hi Aman,
From starting on wards we facing this issue. We didn't change the NTP in recently.
We are using CP-7821, Hope It's not related to specific model, issue is all models those registered in PUB.
I attached utils ntp status, please check and let me know
If you browse to the phone's ip address does it show the correct time and timezone?
I will check and update you shortly
In addition to what Charles has said,can u try restarting ntp from PUB using command utils ntp restart?
regds,
aman
Apart from these, just wanna ensure that phones registered to PUB and SUB are in same device pool. If it is different DPs, please check the Date/Time Group settings of both the DPs e.g. timezones.
Dear All,
Phones are registred in PUB and SUB is different DP, now we change all phones to customized Device Pool. Now it's showing same time.
Thanks for your valuable support
Thanks & Regards
Sivaguru D
