IP2IP gateway with transcoding (SIP2SIP)
goranpilat
Level 3
Level 3
Hello all,
Could somebody with experience in this particular issue help? The thing is I have 2811 with two ip interfaces, both have SIP trunks. one SIP trunk will have g711 and other g729. I need to provide some transcoding. The CCM controlled sccp transcoder is not a possibility since there is no CCM involved. I have PVDMs. How exactly do I do it? Do I need UBE licenses? Any config examples?
Any suggestion is highly appreciated.
best regards and happy holidays,
Goran Pilat
Hi Goran,
This document sounds like it fits exactly what you're looking for:
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a008092d6b3.shtml
You'll do a CME-style transcoding rather than CUCM transcoding.
hth,
nick
hi Nick,,
Thanks a lot for the useful link. So seems like no UBE licenses required... Basically I run telephony-service like I would if the transcoder were controlled by CME...
I'll try it out and let you know.
best regards
goran pilat
