10-11-2011 03:55 AM - edited 03-16-2019 07:25 AM
CUCM get its users from AD. I want every user to have a User Device Profile.
Can I make CUCM create UDPs from template and associate with the new user every time a new user is created in AD?
Terje
Solved! Go to Solution.
10-11-2011 04:17 AM
No, CUCM has no feature in which it will automatically create the profiles for you.
If you need to create a bulk of them use BAT.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
10-11-2011 04:17 AM
java
10-11-2011 04:21 AM
Ok, thank you very much.
