Is it possible to find numbers redirected to my number/extension?
Allan Kjaer
Can anyone tell me if it's possible to find numbers redirected to my number/extension in CallManager?
Manish Gogna
Hi Allan,
There is no tool or report which will show this information. However, this can be tracked by detailed callmanager traces, which will require some effort though. If you are looking at finding information on call forward all setting then it can be done by sql query as described here
https://supportforums.cisco.com/discussion/10865846/call-forwarding-status-cucm-6
Manish
Jaime Valencia
You can always simply do a BAT export and look up for your DN.
java
if this helps, please rate
Hi Jaime,
How do I do this?
Regards.
As I mentioned, go to BAT, and you can do an export all phones or just DNs and then look into the file. Notice this will not include other elements like CTI RPs, for that you would need to look into SQL queries, you can find some at CSC from previous threads on similar questions.
java
