IP Telephony and Phones
Labels
Does anyone know of any concerns, issues, problems, or hidden gotchas that have been experienced with creating a VRF for a VoIP network?  What I would actually like to do is place everything (except the media gateways) in a VRF and firewall it.  Thus...
When I set my 7940 to CFwdAll it forwards both my primary line and my secondary line, I want it to only forward the primary line.I've been told that it's supposed to only forward the primary line and not the secondary but apparently something is diff...
drak23001 by Level 1
  • 569 Views
  • 4 replies
There were some IP Phone 7911 shared the same external number to PSTN and worked properly before.After 7911 has been replaced by 6941, only 1 phone can dial out to PSTN at the same time, the others can't.When the IT crew checked on the configuration ...
c1szhibin by Level 1
  • 575 Views
  • 2 replies
Resolved! AAR CALL ROUTING
I have tried to route the call with AAR in a home lab set up. But i am having a doubt about the call routing issue.I have two branches site HQ and site BR. While the call is denied with standard location CAC, the call is routed to remote site and hit...
Hello,I have a problem with the trunk between CUCM and Asterisk.I can make a call from CUCM to Asterisk, and there is no problem. I can't make a call from Asterisk to CUCM.In Asterisk's log i can see that my call is send to the trunk, with right numb...
Xiuur2508 by Level 1
  • 974 Views
  • 5 replies
Hi Team,I am new to VoIP and trying to understand the traffic flowcan anyone please explain the traffic in the below scenario-Multisite WAN with centralised call processingMainSite A has the cucm and connected to sip providerremotesiteB conected to s...
Hi Everyone,Consider me as a start up person in sql section in CUCM as I wanna know how to run sql for list of directory numbers whose description are marked by specific name:as I tried with run sql select dnoprattern,description from numplan where d...
