Is it possible to install CUCM 6.x, 7.x and 8.x on PC
Hellow Everyone..
Is it possible to install CUCM on a PC with a bootable disk? This is directly installing without VMware!
I know its not supported with Lic and everything but will it work?
Manish Gogna
I believe this will fail during hardware validation check.
Manish
Aaron Harrison
No, it won't work.
You can get VMware for free, and have multiple instances of applications on one host so I see no reason why you would even consider this...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
This is correct.  Why even attempt to do something like this when you can just use VMWare and run as many as you want turning each one on or off as needed?  There are system requirements for CUCM and unless you are in a VM Environment it isn't going to work unless by PC you mean you got a spare UCS/MCS box sitting around somewhere.
