Is it possible to run Nortel VOIP Phones on CUCM?
Paul Hathaway
One of the my Companies Sites over in Ireland has a Nortel Phone System which they are looking to upgrade to VOIP, and there is a Cisco Call Manager Cluster version 4.2 in the UK.
I'm wondering if its possible to Integrate the 2 in some way by either haviing Nortel VOIP Phones running on the CUCM over a Global WAN Link , or an a Local Voice Gateway?
mightyking
Level 6
Level 6
I think the easiest solution is to use H.323 trunk. See if the following helps.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/431470nt.pdf
MK
