IP Telephony and Phones
Labels
Hi, can anyone advise if it is possible on Call manager 6 for a user to be in 2 different pickup groups ? I have heard it can be dne, but you can only select one pickup group from a drop down list so how is it done ?Thanks
systemtek by Beginner
  • 278 Views
  • 2 replies
Hi to all,I have this little problem, I create a simple script .aef for CUE using CUE Editor, in the script I put a "Call Redirect" function and I configure the "Busy" option to play prompt and do other things. But it doesn't work as I want because w...
a.crippa by Beginner
  • 330 Views
  • 2 replies
Hello,I have a customer with more than 100 phones working right, however they have 2 7985 phones that cannot call to external locations through their H323 GW.At the beggining I thought the problem was the "bearer cap speech" because it was not config...
I have a 7sites CME setup with a central gatekeeper.Numbering plan is 4 digits. I am not able to place calls from one particular cme site to others through gatekeeper. Calls fail at Gatekeeper.Gatekeeper Log when call fails:*Nov 2 04:55:34.625: //xx...
prakashar by Beginner
  • 401 Views
  • 4 replies
