Is it possible to use Forced Authorization Codes(FAC) in a CUCM-Lync environment?
mailgunj
Chris Deren
Are PSTN calls go out of Cisco gateway/trunks?
If so, since the FACs are applied to route patterns on CUCM, then that should work, though I never tried it.
Yes, the calls are going through a Cisco Gateway.
I tried doing that, but I'm not prompted to enter the FAC. I tried giving the FAC anyway but the call did not succeed. Just for your information, DTMF digits work while on a call.
Must not be supported then, sorry :-(
Possibly. Thank you so much for your inputs. Really appreciate your help.
Gunjan Jain
