Hi all recently we migrated to CUCM 10.0 using the PCD. The migration is ok, but i can´t login to the Prime License manager co-resident in the CUCM. I try with the same credentials of the CUCM, but it say error user/password Thanks a lotGuillermo
Hi We are using A Cisco 2951 as CUBE. On one site we have a SIP trunk connected to our the SIP trunk provider and on the other side we have a SIP trunk to an IVR application. The Provider sends an options PING to the CUBE and the CUBE answers. So.....
Hi, I would just like to verify if we were to remove the domain name of the CUE will this have any impact. Thank you
Hello all, Sorry for the many questions, but I am confused with some of the security settings and I'm just starting to learn this. Hopefully you guys can answer some of them to get me better understand of it :) Thank you. When I choose to make a se...
Team, I am trying to add a new Cisco 8841 I phone however it is not listed in device defaults.CUCM doesn't give me any option to select 8841 while adding a new phone. How can i add this phone to the CUCM version 9.1.2.thank you
Is there a way to export only one gateway or certain number of phones via BAT? If I use BAT (export/import > export) and select for example gateway, it will export more that 1000 gateways (same with the phone) with FXS/FXO and T1. I just need one so ...
Just curious if anybody has an idea what course of action I have in regards to the 7965 phones which have component issues which cause them to fail after a power cycle. I have reached out to our local Cisco rep with no luck. Also the phones are not...
Hello, I have one issue about one implementation I have CUCM integrated with one PBX. When i receive the call from PSTN the gateway i receive three digitsExample: 403 is send to gateway and the CUCM prefix 0 inside the H323 Gateway, 0403 because the ...
Hi, Call flow is like. Sip trunk (Switch)==> Router IVR==> Core SW==> CUCM. Outgoing call is working, but incoming call disconnects immediately. Debugs are attached. As well tried with cme extension and cucm extension, issue remains same. Regar...
I am setting up a gateway that will connect to 5 PRIs set up on the telco side as NFAS. I was wondering if there was any way to bundle these in NFAS with MGCP or if I have to make this an H323 gateway.
Hi everyone. We have cisco CUCM 8.5 and Cisco 2811 router for gateway and we have E1 for the line telecom. It worked perfectly before but now we can't call outside to CUCM.. When we call to CUCM main number (telcom number) stay silent and drops the c...
Hi all,am new to As5300 Voice Gateway as i got used to work in Cisco CME and CUCM infrastructure.am having As 5350 voice GW with internet connection, 2 cisco ip phones and POE switch.I need to connect (voip calls) to another branch via internet conne...
i have CUCM 10.5.1 and i need to reset web password on that call manager , i know the command to do that : utils reset_application_administrator_ui_password , but im afraid if i apply it on the call manger and i cant login again , how i will change ...
Greetings, I was wondering if anybody ever got the group listen feature to work on these phones? I can't seem to find it in a softkey template or phone setting even though the feature is in the network setup stats on the web page of the phon...
Hi, I have a customer that has the above CUCM version and I need to install the appropriate device pack for the CUCM to now support the 7800 phones. Can you advise what version of device pack to use for this call manager? Or do I always use the late...
| Subject | Author | Posted |
| 12-10-2025 11:24 AM | ||
| 12-10-2025 05:17 AM | ||
| 11-16-2025 10:18 PM | ||
| 10-15-2025 09:15 AM | ||
| 09-26-2025 02:09 AM |
| User | Count |
| 4 | |
| 2 | |
| 1 | |
| 1 | |
| 1 |
