Is there a better 8800 wall mount?
davisjaron
The older 796X series phones had a really nice locking wall mount that sat the phone at an angle so if you're standing, you can still see the screen, but for some reason the newer 88XX series phones only have the one flat wall mount available that uses that terrible system where you have to use the pin holes on both sides to take the phone off the wall.
I found a single after market wall mount that uses the older standard style mount rather than using a two piece bracket, but it also holds the phone flat against the wall rather than at a usable angle.
Does anyone know of any wall mounts that are easier to mount and remove, as well as sits at an angle?
Old locking wall mount:
Image result for 7962 locking wall mount
New Non-Locking Wall Mount:
Image result for 8851 wall mount
After market, but still flat and non-locking wall mount:
0 Replies 0
