05-25-2015 09:15 AM - edited 03-17-2019 03:07 AM
Hi ,
If you have possibility to help on my case.
Can you tell me which translation profile for inbound and dial peer for inbound can i used for these inbound calls:
If a number from a mobile phone with number 069 243 234 or any other call on my DID number which is 0739 443 590
If a number from a national PSTN phones with number 0739 333 444 or any other call on my DID number which is 0739 443 590
If a number from a International call with number +123 4567 2223 or any other call on my DID number which is 0739 443 590
My extension numbers are [1-9]xxxx
On CME on debug isdn q931 i have this notify : Invalid number format
Best Regards
05-25-2015 10:31 AM
Hello Leo,
The description is not clear enough, can you please try to explain the problem again?
Thank you,
Shadi
05-25-2015 10:39 AM
Hi Shadi
Thank you for your reply,
Provider has given us the DID number 0739 443 590.
I want to create a inbound translation profile and Dial peer that when a mobile number phone from PSTN with number 069 243 234 when comes on number 0739 443 590(DID) to ring on my extension :10200
Best Regards
05-25-2015 10:51 AM
So when thag specific number (069 243 234) dials into (0739 443 590) the call should be landing into your internal extension (10200), what should happen when other numbers call same DID number?
In which format pstn does send the dialed number? (debug isdn q931 helps).
Can you attach the running config?
05-25-2015 10:59 AM
Hi Shadi,
Tomorrow i will send you the config file and also debug isdn q931
Thank you very much for you help
05-26-2015 10:18 AM
First dial the number and do a debug isdn q931 to get the called number. Now create that same pattern in dial peer and send the call to call manager. next in call manager use the proper CSS on which gateway incoming calls are assigned and create the translation pattern to expand it to full number which you are assigning to the extension.
