04-12-2011 02:41 AM - edited 03-16-2019 04:28 AM
I've a problem with a couple of ISDN E1 Channel who not release.
If im looking with show voice call summary they are 3 channels are busy. But when i looking with show isdn active there is no active call.
When the CUCM will start a new call and take the blocked channel the user will hear the busy tone.
tcehve#sh voice call summary
PORT CODEC VAD VTSP STATE VPM STATE
0/0/0:15.15 - - -
0/0/0:15.17 - - -
0/0/0:15.18 g711ulaw n S_WAIT_STATS S_TSP_DISC_PROG_IND_REL
0/0/0:15.19 - - -
0/0/0:15.20 - - -
0/0/0:15.21 - - -
0/0/0:15.22 g711ulaw n S_WAIT_STATS S_TSP_DISC_PROG_IND_REL
0/0/0:15.23 g711ulaw n S_WAIT_STATS S_TSP_DISC_PROG_IND_REL
tcehve#sh isdn act
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
Has anyone an idee to fix this problem?
Thanks Roland
04-12-2011 11:37 PM
Which voice gateway are you using to terminate this ISDN PRI E1 ? also let me know the product details and the call flow. Thanks
04-13-2011 05:41 AM
i would like to explain our design. We have the Cisco 3800 ISR and 2800 ISR Router in service as Voicegateway.
I've more than one Gateway with this problem and it sounds on a Software bug. I have isolate one router to troubleshoot.
The Design is for inbound we use a Gatekeeper for outbound the CUCM have a routepattern.
All Gateways work as H.323 Gateway
I have blocked the good channels. Now i can simulate a fault call. You can see the Channel 23 is used by the Gateway although the channel is occupied.
Here ist the Show version of this router:
tcehve#sh ver
Cisco IOS Software, 3800 Software (C3845-IPVOICEK9-M), Version 12.4(24)T4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 03-Sep-10 10:00 by prod_rel_team
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
tcehve uptime is 8 weeks, 2 days, 4 hours, 29 minutes
System returned to ROM by reload at 08:37:26 MET Mon Feb 14 2011
System restarted at 08:38:56 MET Mon Feb 14 2011
System image file is "flash:c3845-ipvoicek9-mz.124-24.T4.bin"
Cisco 3845 (revision 1.0) with 487423K/36864K bytes of memory.
tcehve#csim start 00583388355
csim: called number = 00583388355, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(849252)
Apr 13 13:51:50.956: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x3C35 callID = 0xB96A switch = primary-net5 interface = User
Apr 13 13:51:50.956: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x3C35
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Called Party Number i = 0x80, '0583388355'
Plan:Unknown, Type:Unknown
Apr 13 13:51:51.024: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xBC35
Apr 13 13:51:51.468: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xBC35
Apr 13 13:51:51.468: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x3C35
Cause i = 0x80AF - Resource unavailable, unspecified
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
tcehve#
0/0/0:15.19 - - -
0/0/0:15.20 - - -
0/0/0:15.21 - - -
If you use more detail let me know.
Sincerely yours
Roland Marti
04-17-2011 11:52 PM
Hi Roland
Thanks for the info. Its hitting an error " S_TSP_DISC_PROG_IND_REL ". Can you let me know is the channel stuck /hung happening for FAX calls or Normal voice calls ?
Lavanya
04-20-2011 12:18 AM
Channel stuck is due to the Error "S_TSP_DISC_PROG_IND_REL" and reported as bug CSCdv61378,CSCdu66815.. But Fix has been committed way back in IOS 12.1 and later images.
So as per my understanding, you shouldnt be hitting this Error in 12.4(24)T4 IOS which you are using currently.
